Oil Brand and Grade
Oil Brand and Grade
Postby 83841 » Wed Nov 16, 2011 1:40 pm
What brand of oil and grade do you use for your GT4?
-1977 Celica GT (white) Sold
-1980 Celica Coupe (Brown) Sold
-2000 Celica GT-S (Black) Sold
-1993 MR2 (Teal) Sold
-2007 FJ Cruiser (Black) Sold
-2006 Evo IX MR (Grey) - Garaged
-2008 S2000 (Silver) - daily
-1994 Celica GT-FOUR - WRC (Silver) - Garaged
83841
Re: Oil Brand and Grade
Postby Terracar » Wed Nov 16, 2011 1:50 pm
Mobil 1 synthetic 5Wx30. The 5qt jugs are dirt cheap in my area so it is a no brainer.
-Terracar
Terracar
Postby 88gt4DE » Wed Nov 16, 2011 7:01 pm
+1 Mobile 1 synthetic 5w-30
Postby 83841 » Wed Nov 16, 2011 7:57 pm
Dont you think 5-30 grade is kinda thin? Is it bad to run 10-30?
83841
Postby aus jd 2703 » Wed Nov 16, 2011 8:42 pm
your first number or thw w is your winter grade, its oil at cold so really if it never goes near 0'c 10w is fine i run 20w-50 as its summer and our miniumum is 15'c and our maximum will be high over 38'c.
if you track you car often go for a heavier grade like 20-50 as it will be thicke at the higher temps and protect better.
mobil one? im all royal purple and redline lol but then i baby my car
aus jd 2703
Postby sMARTINside » Wed Nov 16, 2011 9:01 pm
A 10W-30 oil is going to be at the same viscosity than a 5W-30 oil at high temperatures, but it will be thicker at lower temperatures.
Since you are in California (high temps), you should use an oil that has 40 or 50 as second grade.
On my side, I use Shell Rotella T6 (5W-40) It is a tough synthetic oil that is formulated for diesel engines. It has good characteristics and is easy to find and cheap.
I think that Toyota recommends 5W-40 in the 3S-GTE, but I am not sure.
sMARTINside
Postby concealer404 » Wed Nov 16, 2011 9:51 pm
Castrol Syntec 10w-40.
Cars and stuff.
concealer404
Postby Flying Bajan » Thu Nov 17, 2011 1:13 pm
Mobil 1 10-50 or Amsoil 10-40. High ambient temps.
Flying Bajan
Postby underscore » Thu Nov 17, 2011 2:15 pm
So far I've only had it for one change and it's got Amsoil synthetic, I'll use that or Castrol synthetic in the future. For my GT-S I stick to regular Castrol, but anything EXCEPT Penzoil and Quaker State are fine.
Postby Texasnick » Wed Nov 30, 2011 5:54 pm
Redline 10w30
Tried 5w30 last winter but the engine was a little louder on warm up so I try to stick with the 10 weight.
Plan on messing around with different weights this summer once I get a pressure gauge hooked up.
Texasnick
Postby Shaggz00 » Wed Nov 30, 2011 6:10 pm
You are gonna get a bunch of different responses for this one. I run 20w50, and have for 7 years. I switched to Mobil1 Synthetic a few years ago, I found that it provided better PSI than the Royal Purple 20w50, and had the added benefit of being 2/3rds the price. I have a digital oil PSI gauge, btw. I saw about a 7psi increase at full throttle with the Mobil1.
-Avi-
Shaggz00
Return to GT Four Chat
