ST205WRC troubleshooting
Postby LechacZ » Tue Jan 24, 2012 11:01 pm
Hi guys,
I have a 1994 ST205 WRC.
The car developed a weird problem. It cuts fuel really violently at about 8psi.
At least I think it is fuel cut as it feels like fuel cut on overboost.
No Check Engine.
I am puzzled...
I have already replaced the turbo pressure sensor (MAP?) as I had aspare from my now retired ST185 with ST205 swap.
Any suggestions?
I need some help! Please!
Thanks
Les
ST-205
Ontario, Canada
LechacZ
Re: ST205WRC troubleshooting
Postby klue » Tue Jan 24, 2012 11:33 pm
Did you check for hidden codes?
Postby LechacZ » Thu Jan 26, 2012 4:10 pm
Yes I did look up the codes and I have a 34 and 54.
I don't know how long they have been there but I do have an explonation for both.
When I installed the boost controller I had the over boost a few times and 34 is just that - the check engine is supposed to stay ON when this code is detected and I have no check engine when this is happening.
54 is just the IC collant low...
Les
ST-205
Ontario, Canada
LechacZ
Postby klue » Thu Jan 26, 2012 7:13 pm
fill up the intercooler
Postby LechacZ » Thu Jan 26, 2012 8:15 pm
Thanks, it is full... 54 is a stored code
Les
ST-205
Ontario, Canada
LechacZ
Postby klue » Thu Jan 26, 2012 8:29 pm
clear codes and try again. it will do a limp mode for that one
Postby LechacZ » Fri Jan 27, 2012 11:44 am
Yeah, cleared codes, tried boosting = fuel cut, no new codes
Man this is frustrating
Les
ST-205
Ontario, Canada
LechacZ
Postby klue » Fri Jan 27, 2012 12:53 pm
No new ones, or the same old ones?
Im going to send you my number text me or something, I got class all day so wont be able to talk until later
Postby LechacZ » Fri Jan 27, 2012 1:36 pm
No codes at all now.
I'll text you later in the aft. bussy at work...
Les
ST-205
Ontario, Canada
LechacZ
Postby LechacZ » Sun Jan 29, 2012 3:05 pm
Well, I have replaced the ECU with a spare I know works well and same thing - fuel cut at about 10 psi.
Now the fun will begin... :shrug:
Les
ST-205
Ontario, Canada
LechacZ
Postby underscore » Sun Jan 29, 2012 4:22 pm
bad wiring on the pressure sensor? I'm not sure what kind of signal those send though.
edit: do you have a wideband? are you perhaps knocking?
Postby klue » Sun Jan 29, 2012 4:40 pm
map sensor is 5v reference, if it was bad you would have other issues else where
If you can figure it out Les let me know and you can bring it by
Luke
Postby tubasteve » Sat May 19, 2012 9:23 pm
Bad iGnitor? It won't set a code, similar to doing a 185-205 electronics fuel cut, and keep getting worse, then disappear at times. I had a customer with this issue. Free revving it would fuel (ignition) cut at low rpm and never consistent.
-jr
tubasteve
Postby GMan » Sat May 19, 2012 9:47 pm
Quick google.
http://www.troublecodes.net/Toyota/
34 Turbocharging
pressure signal
The 34 is "Overboost" Where is the pressure sensor located ?
Bad wire or bad ground somewhere ?
Do you have a Real boost gauge ? ?he stock one is not very accurate.
What boost are you reaching ?
54 Inter-cooler ECM signal.
Could be the IC level sensor or the pump....
Good luck.
GMan
Postby tubasteve » Sat May 19, 2012 10:06 pm
LechacZ wrote:Yeah, cleared codes, tried boosting = fuel cut, no new codes
Last he had ?
Op fix this yet?
tubasteve
Return to GT Four Chat
