AC delete in an RC
• Page 1 of 2 • 1, 2
AC delete in an RC
Hey guys, I'm trying to get the AC out of my RC, I've already got the pump off the block and the two lines that were attached to it removed, as well as the AC fan. The front bumper is now off and I've realised that the intercooler sits in front of the AC, with another small cooler bolted to the right side of it (I was originally under the impression that the AC was at the very front).
My question is as follows: what is the easiest way to remove the AC at this point? can it be done without dumping the intercooler water, the engine coolant and whatever else is running through the cooler in front of everything? what the heck do I remove, as it looks like everything is blocked in on all sides.
1987 GT-S -> rust in piece
1991 RC -> project http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=44216 "Darlinda the Tie Fighter"
1992 GT-S -> daily
2000 Cherokee -> ski hauler
1997 Prelude -> girlfriends daily/project "Charmeleon"
1992 GT-S -> daily
- Established Member
Re: AC delete in an RC
underscore wrote:Hey guys, I'm trying to get the AC out of my RC, I've already got the pump off the block and the two lines that were attached to it removed, as well as the AC fan. The front bumper is now off and I've realised that the intercooler sits in front of the AC, with another small cooler bolted to the right side of it (I was originally under the impression that the AC was at the very front).
The coolers in front are p/s, and Trans coolers. I think that's it.
feb. 1990 alltrac red one: fun machine http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27076#p253730
feb. 1990 alltrac blk one:dd
5x114.3 write up:
http://www.alltrac.net/phpBB2/viewtopic.php?f=20&t=43769&p=411470#p411467
5x114.3 write up:
tubasteve - Established Member
He has an RC, so he also needs to remove the A/W heat exchanger.
No, you need to pull those all off... it's not a big deal though. with the power steering pump cooler and the tranny cooler, just unbolt them from the frame and pivot them out of the way.
- temperacerguy
He also thought the condencer is in front. i was kindly stating what was in front of that.
5x114.3 write up:
5x114.3 write up:
yeah I remember being told that there was no point in hooking up the intercooler sprayer if the AC was still there, because the AC was in front of the WTA. So now how do I go about dropping the intercooler and then the AC? I'm assuming start pulling bolts and eventually the bottom edge will swing out so I can pull it down?
Also what is the metal cylinder sitting vertically and in front of the right edge of the intercooler? It looks like part of the AC system so I can remove it?
1992 GT-S -> daily
1992 GT-S -> daily
Oh and does anyone have the procedure for burping the intercooler once I put everything back together?
1992 GT-S -> daily
1992 GT-S -> daily
Does the cylinder have a red or black cap which protrudes out of the right side of the plastic cooling panel? If so, its part of the AC and can go.
Corey Darling - GTFour God
- Images: 50
The metal cylinder you speak of is the reciever/dryer and can be thrown out. Its purpose is to collect moisture in the AC system.
Allen
1990 Volvo 760 Turbo "Go fast for Less" Daily
1992 Toyota Celica Alltrac "Go nowhere for More" Project
2012 Lexus ES350 "Kid Taxi" Wifes Daily
- ALLensTRAC
it doesn't have a cap on the top nozzle and my cooling panel is MIA, I'm pretty sure the drivers front corner of the car got a bit crunched at one point
Thanks Allen, I'll yank it out then.
1992 GT-S -> daily
1992 GT-S -> daily
Is there a right up anywhere about removing the AC in my ST185?
I don't use it and would like to get it out of there.
awolo - Club Member
There is a write up with pictures on www.gtfours.co.uk under "how-to"
I can't give you a direct link, it wont work. But it takes 5 seconds to find in the drop down menu on the left.
- Images: 50
Is the gtfours.uk.co site down?
I need to to see a write up on AC removal. The last part that shows which connector to wire so my Radiator fan stop running constantly.
awolo - Club Member
http://www.gtfours.co.uk ?
Hmm doesn't work on my phone either.
The connector u need to bridge is the pressure switch located on the hardline as it enters the firewall. Just use a wire inserted into 2 of the 4 pins in the connector - wide wise, not narrow.
Other option is to remove sensor from hardline and leave it plugged into connector
- Images: 50
Yeah, it just keeps taking me to some default site.
I'm trying to find that picture of the connector though, as I'm not exactly sure which one it is.
My plan is to wire it up with a switch. This way I can turn it on whenever I would like, (track days/AutoX), but then also just turn it off for normal DD use.
awolo - Club Member
I´m about to remove my AC in a few weeks. There are some people interested, is it posible to install the AC in a T18 which wasn´t equipped with that?
- michicop
