RC/CS CT26 vs normal st185 CT26
Re: RC/CS CT26 vs normal st185 CT26
Postby alltracman78 » Wed Mar 28, 2012 11:23 am
No, "stock" boost is normally 8 PSI.
8 - 12 PSI is acceptable in the service manual but 8 is what it normally is.
And I don't think the 185 MAP sensors can read up to 17 PSI. I'm not positive on that, but I'm pretty sure.
I do know the RC has the same MAP sensor as the regular ST185s.
Postby tubasteve » Wed Mar 28, 2012 7:08 pm
Fuel cut is 12psi is "fact" is what i ment.
-jr
tubasteve
Postby Broz » Wed Mar 28, 2012 7:23 pm
WRC versions have a number of subtle differences to All-tracs & std GT4's the ECU & map sensors is just one of many.
One of the guys here in NZ fully restored his RC & in the process found a large number of parts different to std GT4's so he couldn't just use GT4 parts.
Cheers
Mark Brosnahan (Broz)
2 X 91 GT FOUR RC's 1 White 1 Red
May the FOURce be with you
Broz
Postby athousandleaves » Fri Mar 30, 2012 4:51 am
From what I gather the 'ct20b' is also a super back design compressor vs the flat back design in the other generations of the ct26.
And yeah all the gens got the same MAP sensor part number but the MR2's got different ones...
~Edit~
http://gtfour.supras.org.nz/mapsensor.htm
185 MAP is good to 18PSI
205 MAP is good to 26PSI minimum!!!
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby MWP » Sat Mar 31, 2012 6:41 am
athousandleaves wrote:And yeah all the gens got the same MAP sensor part number but the MR2's got different ones...
~Edit~
205 MAP is good to 26PSI minimum!!![/quote]
Gen4 is different from the others.
Postby l0ch0w » Sat Mar 31, 2012 9:44 pm
Fuel cut happens around 10psi.
Stock boost is 8 psi
ALL stock 3sgte's boosted between 8 and 10psi
Gen 3 fuel cut is 15psi
I cant say I know enough knowledge about the stock RC ST185 or the WRC ST205 and what their stock fuel cut thresholds actually were.
Andrew
1991 Red Alltrac
l0ch0w
Postby tubasteve » Sat Mar 31, 2012 10:24 pm
l0ch0w wrote:Fuel cut happens around 10psi.
No, fuel cut on the 185 is 12, on the 205 is 17.
The rc is 17 as well.
tubasteve
Postby tubasteve » Sat Mar 31, 2012 10:29 pm
http://www.alltrac.net/tuning/fuelfaq.html
did a lot of testing myself....but here you go, I'm not the only one.
tubasteve
Postby underscore » Sat Mar 31, 2012 11:13 pm
I'm 95% sure stock boost is 6-7 in 1/2 and 10-11 in 3/4/5, at least on the 185.
Postby Corey » Sun Apr 01, 2012 12:31 am
And just to add to the confusion - my car's fuel cut is 14
Corey
Images: 50
Postby tubasteve » Sun Apr 01, 2012 1:07 am
Corey Darling wrote:And just to add to the confusion - my car's fuel cut is 14
Lazy map sensor then. Or you have something teed into the map sensor.
tubasteve
Postby tubasteve » Sun Apr 01, 2012 1:08 am
Id say this is true. More load in 3-5
tubasteve
Postby Corey » Sun Apr 01, 2012 1:45 am
The boost gauge I was using was T'd into the MAP sensor line. I've also checked the BGB specs on the MAP sensor using a multimeter and it was within spec :shrug:
Corey
Images: 50
Postby tubasteve » Sun Apr 01, 2012 1:47 am
Lazy map then
tubasteve
Postby underscore » Sun Apr 01, 2012 1:52 am
I thought fuel cut was supposed to be at 14psi?
Return to GT Four Chat
