can you help
can you help
Postby fiddler69 » Fri Jul 06, 2012 4:12 pm
i have a celica gt4 st205 can you tell me do you have to run a ventilation case or can you bypass it ,many thanks ,richard
fiddler69
Re: can you help
Postby Gary ST165 » Fri Jul 06, 2012 4:15 pm
ventilation case : do you mean oil catch can?
many do and many choose not to...
personally i would keep the PCV as toyota intended.
hth
ST165 turbo 4WD
Gary ST165
Re: can you help
Postby fiddler69 » Fri Jul 06, 2012 7:57 pm
thanks for ur advice can you tell me if the pipe from it gos to the big pipe coming off the the bottom of the throttle body please
fiddler69
Re: can you help
Postby Corey » Fri Jul 06, 2012 10:13 pm
PCV Hose comes off of the valve cover under the intercooler. The hose running to the throttle body is for the idle speed control valve.
Corey
Images: 50
Return to GT Four Chat
