3" Exhaust Install + Broken Manifold Stud = Less power?
Re: 3" Exhaust Install + Broken Manifold Stud = Less power?
Postby awolo » Wed Jul 18, 2012 4:08 pm
I do agree, it would be easier to remove the stud if the manifold was removed. I'm going to try this. Best case it works, worst case it doesn't, and I have to remove everything anyway.
But unfortunately, I dont have the time/tools to remove the manifold/turbo/lines/down pipe. :(
awolo
Postby toayoztan » Wed Jul 18, 2012 9:42 pm
For future reference, if you can grab a piece of the manifold stud that snapped off, just use a small plumber's pipe wrench. That thing has never failed me. You will tear up the stud in an epic manner (not that you planned on reusing the stud), but it's a great tool - after heating and PB blaster, it was a cinch.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby 4rsnduction » Wed Jul 18, 2012 10:27 pm
Ahhh the one finger salute, merit badge of a job well done :D
4rsnduction
Postby awolo » Thu Jul 19, 2012 12:24 am
I GOT IT OUT!!!
WHOOOO!!!!
I F**KING GOT IT OUT!
awolo
Postby toayoztan » Thu Jul 19, 2012 3:05 am
Nicely done!
What's your method of installing new exhaust mani studs? I've read conflicting info.
Loctite or no loctite?
Hand tight or torque down?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby jaydog82 » Thu Jul 19, 2012 4:10 am
Woot woot. I had one brake on me, I bought a special tool and it removed it. I installed new own studs with red locktight.
jaydog82
Postby toayoztan » Thu Jul 19, 2012 4:29 am
Did you hand tigthen or torque them in?
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby jaydog82 » Thu Jul 19, 2012 4:54 am
As tight as I could get them by hand + the locktight so they should be good. Make sure u get own studs the aftermarket ones are crap.
jaydog82
Postby toayoztan » Thu Jul 19, 2012 5:55 am
Well, I read that you don't want to use loctite, and if you do, you want to secure the manifold before it sets (due to the technical way that the stud works).
That's what I'm trying to figure out.
I bought OEM studs, but I used the double nut method to get them on there pretty damn tight. Now I'm thinking that isn't the best thing to do.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby loudstealthGT-Four » Thu Jul 19, 2012 7:32 am
I bought all new studs when I replaced my turbo, I. Just screwed the studs in finger tight and then put the manifold on and tightened the nuts as much as I could. I'm using different nuts than OEM , just went and bought some from local fastener place, they have a serrated back on them to lock them tight
loudstealthGT-Four
Postby awolo » Thu Jul 19, 2012 10:24 pm
Exhaust stud replace.
Exhaust leak fixed.
Car is still down on power. Not sure whats going on.
awolo
Postby underscore » Thu Jul 19, 2012 10:35 pm
Silly question, but did you reset the ECU?
Postby awolo » Thu Jul 19, 2012 11:30 pm
I did not.
Should I?
awolo
Postby underscore » Fri Jul 20, 2012 12:32 am
Yes
Postby awolo » Fri Jul 20, 2012 12:39 am
Disconnected the NEG cable from the battery, waited 20-30 seconds re connected.
Going for a drive now. Will report back.
awolo
Return to GT Four Chat
