3" Exhaust Install + Broken Manifold Stud = Less power?
Re: 3" Exhaust Install + Broken Manifold Stud = Less power?
Postby awolo » Fri Jul 20, 2012 1:05 am
Seems to have helped alot.
Curious, should the ECU be reset after all performance adding/changing mods?
awolo
Postby loudstealthGT-Four » Fri Jul 20, 2012 2:19 am
Generally yes, let's the ECU recalculate everything to the new setup.
loudstealthGT-Four
Postby jaydog82 » Fri Jul 20, 2012 4:09 am
Btw you need to do more than remove the neg cable, remove the efi relay from the main fuse box in the engine bay for 10-15min will do the trick
jaydog82
Postby celigts » Fri Jul 20, 2012 1:42 pm
The edu or ecu lol. And unplug it from where? I'd like to do this as well.
3SGTE project motor very slow
celigts
Postby jaydog82 » Fri Jul 20, 2012 2:32 pm
Post is fixed lol stupid auto correct
jaydog82
Return to GT Four Chat
