ST-205 GT4 Wheel Alignment?
Postby 83841 » Thu Aug 16, 2012 3:10 am
Does anyone know if getting an alignment done on a GT4 with superstrut suspension is any different than any other celica with McPherson setup?
-1977 Celica GT (white) Sold
-1980 Celica Coupe (Brown) Sold
-2000 Celica GT-S (Black) Sold
-1993 MR2 (Teal) Sold
-2007 FJ Cruiser (Black) Sold
-2006 Evo IX MR (Grey) - Garaged
-2008 S2000 (Silver) - daily
-1994 Celica GT-FOUR - WRC (Silver) - Garaged
83841
Re: ST-205 GT4 Wheel Alignment?
Postby Awesome-Trac » Thu Aug 16, 2012 4:14 am
I would think it would be simple seeing how every car has a caster, camber and toe but I can be wrong
•Daniel
Awesome-Trac
Postby alltracman78 » Thu Aug 16, 2012 12:44 pm
A normal alignment should be the same, the rear is identical to the ST185, and the front toe is adjusted the same.
The problem would be if the front camber was off, you can't adjust it with the lower strut bolts [not normally adjusted in a car], but I'm sure there's a way.
Postby 83841 » Thu Aug 16, 2012 1:06 pm
alltracman78 wrote:A normal alignment should be the same, the rear is identical to the ST185, and the front toe is adjusted the same.
Lower strut bolt?
83841
Postby alltracman78 » Thu Aug 16, 2012 3:58 pm
Where 103 attaches.
In a Macpherson strut setup it's different.
Postby 83841 » Wed Sep 05, 2012 2:12 pm
Not possible...The nut holds the top ball joint down...I think the only way to adjust the front cambers on a super strut layout is to purchase front camber plates like so:
http://www.fensport.co.uk/Parts/Model_1 ... ory_2/2238
I am only able to adjust the toe....by adjusting the Outer Track Rod End
Oh another method of adjusting the camber is if you have the TEIN SS
83841
Return to GT Four Chat
Users browsing this forum: Yahoo [Bot] and 2 guests
