Shifter Cables
Shifter Cables
Postby MrMcQuacker » Fri May 17, 2013 5:56 am
Hey guys, I have to change mine out soon. I just wanted to ask I have a st165, will st162 shifter cables work with my st165? Also is there any other alternative besides using st165/162? just curious.
MrMcQuacker
Re: Shifter Cables
Postby jsd » Fri May 17, 2013 6:23 am
Same cables for any st16x
jsd
Re: Shifter Cables
Postby aus jd 2703 » Fri May 17, 2013 9:51 am
Does any one know if the same applies to st18x series?
Sorry for the thread hijack
aus jd 2703
Re: Shifter Cables
Postby jsd » Fri May 17, 2013 7:37 pm
Yeah I cross referenced the part numbers and same applies to st18x and at180
jsd
Re: Shifter Cables
Postby dkdmonk » Fri May 17, 2013 9:51 pm
Not so fast :bs:
ST18X
I don't think they are the same. Same length, same mount at shifter, not same at trans mount.
I pulled some off a GTS and thought they would work BUT they don't mount up the same where the "fixed" (outer) cable mount is held in place with the brake line like push tab.
Found a thread here where someone else found out the same thing and they built a washer stack spacer to get them to work. This is what I need to do just haven't yet.
Hope this helps! They will fit, just not without other work.
dkdmonk
Images: 12
Re: Shifter Cables
Postby MrMcQuacker » Sun May 19, 2013 8:53 pm
Now does that go for the st165 as well or does that spacer thing only apply for the st185?
MrMcQuacker
Re: Shifter Cables
Postby dkdmonk » Sun May 19, 2013 11:11 pm
Sorry Bro,
I only know that info for ST185 and ST184. Not sure about the 16X series.
dkdmonk
Images: 12
Re: Shifter Cables
Postby MrMcQuacker » Mon May 20, 2013 2:49 am
:( hope someone can tell me a definite answer.
MrMcQuacker
Re: Shifter Cables
Postby MrMcQuacker » Sun Jul 21, 2013 6:13 pm
MrMcQuacker
Re: Shifter Cables
Postby fussellbug » Sun Jul 21, 2013 10:20 pm
The ST162 uses the S53 transmission which has shifter cable mounts cast into the transmission housing. These cast mounts are thicker than the sheet metal ones on the E50 so the ends of the cables are slightly different.
The upper one is what your ST165 cable should look like and the lower one is what the ST162 would look like.
(these are actually AT180 and ST184 cables from S53 and C52 transaxles but have the same mountings)
You may be able to use a spacer to mae the ST162 cable work since they have a longer lip to work with.
fussellbug
Images: 36
Re: Shifter Cables
Postby celicast184 » Mon Jul 22, 2013 1:49 am
i used some washers from axle bolts. i cut a portion of it out so it looks like a C. slip thos into the cables then the clip holds it all together.
I <3 MY ST214
celicast184
Return to GT Four Chat
