Dumb Question im sorry.
Postby MrMcQuacker » Fri Aug 23, 2013 11:17 pm
I bought bushings that needed to be replaced but I don't know what exactly is it I need. I found out that I have bought rear lower trailing arms bushings and some bushings for the front. I need to know what are the other 8 bushings on the hub besides the really big one. I found some from twosrus ST165/ST185 Rear Control Arm Outer Polyurethane Bushing but I just want to make sure those are not the ones I already have.
I can't explain it to well but hopefully those who think about my explanation, you won't get to lost.
When you take out the hub there are 3 bushings on it. 2 small ones and 1 big one in the center between the 2 small ones. I have the big one in the center but I need the 2 small ones. I know they are spherical types but I don't want those. I want the actual polyurethane one. And if I remember correctly by watching a write up on how to install them. There are 8 bushing I think 4 bushing and 2 tubes per hub. ( what are the name of those bushings?)
MrMcQuacker
Re: Dumb Question im sorry.
Postby spitfiremk16 » Fri Aug 23, 2013 11:36 pm
Use the spherical bushings from toyota. Here is a write up with part #'s.
http://www.planetcampbell.us/SphericalB ... ement.html
Here is why you use spherical bushings on the wheel hub side of your #1 and 2 suspension arms
viewtopic.php?t=21366&highlight=#wrap
And here is all the part numbers you need to order all suspension bushings from the car from various manufacturers
viewtopic.php?f=4&t=44200
spitfiremk16
Postby MrMcQuacker » Sat Aug 24, 2013 12:37 am
Thank you. Is it possible to get the source for Poly? I have read about spherical and poly and so far. I have driven in a full Poly BMW and other Celicas and it honestly does not feel so bad. I will look at price and compare. But if possible may I get the source for the Poly 1/2 radius?
MrMcQuacker
Postby MrMcQuacker » Sat Aug 24, 2013 12:39 am
I apologize if it seems like I am not thankful for the insight. I actually already read the pros and cons, and I have decided to follow the route of the others that have my car and have Poly bushings.
MrMcQuacker
Postby Boo_Guy » Sat Aug 24, 2013 12:19 pm
Here you go, pretty much every poly bushing you could want is here;
http://www.gt4-racing.eu/index.php/toyota-celica-st185
I have their front, rear (minus the 2 spherical from toyota) and rear diff on my car and have no complaints. My mechanic warned me that they might squeak but I havent had any issues.
Another company that makes them is called http://www.superpro.com.au/
You should really look into getting those two spherical bushings from Toyota though, theyre actually better than the polys. All the rest can be poly though.
Boo_Guy
Postby lumbercis » Sat Aug 24, 2013 8:05 pm
SuperPro also makes those bushings. If you search around on ebay or google you should be able to find a source that sells them.
Caldina powered...
lumbercis
Postby MrMcQuacker » Sat Aug 24, 2013 9:26 pm
Are the Superpro bushings from twosrus the replacements for the ones I am looking for?
MrMcQuacker
Postby MrMcQuacker » Wed Aug 28, 2013 5:12 am
MrMcQuacker
Return to GT Four Chat
