can anybody tell me the difference
Postby Paykoo » Mon Aug 26, 2013 10:48 pm
can anybody tell me the difference between spacing on the gen 2 n gen 3
is it the spacing between injectors ? or height ?
Paykoo
Re: can anybody tell me the difference
Postby underscore » Mon Aug 26, 2013 10:52 pm
The spacing...on what?
Postby Paykoo » Mon Aug 26, 2013 10:58 pm
i dunno evrytime i post about fuel rails i get this " the spaceing is different from a gen 2 to a gen 3"
i want to know what spacing is different
reason behind this is i want to go topfeed
but im on a budget
80 bux sounds better than 200 ...
so i would really like to know the difference between one to the other if its mounting i can fix that
but if injector holes are drilled in different locations then i cant do nothing
and have to pay double ;)
thanks for you reply
Paykoo
Postby underscore » Mon Aug 26, 2013 11:24 pm
I'm assuming you have a gen 2? If so, I believe the 5SFE rail fits to convert to top feed.
Postby RedCelicaTRD » Tue Aug 27, 2013 1:04 am
Gen 3 is side feed so it really doesn't matter. Gen 1 is top feed, and if you search this rail has been used on a gen 2.
Unless you want to use a 3sge rail.
Postby brutekiller787 » Tue Aug 27, 2013 2:07 am
Or An St165 Rail. I've Done It. All That's Needed Is 2 Brackets. Not Very Hard. I Believe On A Gen2 The Space Between Cul 2 And 3 Is Bigger Than 1+2 And 3+4, Whereas Gen3 The spaces Are The Same All The Way across
brutekiller787
Postby polm » Tue Aug 27, 2013 1:41 pm
You can use a 5sfe rail and cut the cups off the 2nd gen 3sgte rail, that's what I did. Very very cheap lol total cost was less than 20 $ (not counting injectors obviously). I use modded wrx injectors, they flow upwards of 800cc and can be found for under 100 $.
polm
Postby brutekiller787 » Tue Aug 27, 2013 5:02 pm
OT: Get Me Some Lol. cheapest I Can Find Is 200 Plus Because People Know About Them now
brutekiller787
Postby polm » Thu Aug 29, 2013 3:51 am
brutekiller787 wrote:OT: Get Me Some Lol. cheapest I Can Find Is 200 Plus Because People Know About Them now
Quick search on nasioc brought many up, here are just 2 of the adds that have them for less than 100$ shipped:
http://forums.nasioc.com/forums/showthr ... x+injector
Those are the ones you want, the blue ones (02-07 wrx, sti's won't work!). They flow 440cc stock, once modded they flow upwards of 800cc.
polm
Postby psipwrd » Thu Nov 07, 2013 6:23 am
Are you modding then sending them off to get flow tested? They can be all over the board, from 800-880cc...
psipwrd
Return to GT Four Chat
