Looking at Buying a 1991 Celica GT-Four ST185
Postby bleach » Sun Nov 03, 2013 12:40 am
I am looking at buying this car, What are the things to look out for. (besides the standard used car checks.)
I will be looking for a new door for it, can I use a door off a Non-GT-Four and a left hand drive car? (my body skills sucks.)
Heres the info I have, the guy had to put new seal/bearings in the rear diff.
JDM right hand drive
Lowered on adjustable D2 coilovers w/matching wheels
Completely new exhaust 3" pipe
K&N cold air intake
New spark plugs/wiring
New sway bars/links
CT26 Twin entry turbo
159,000km
Comes with 2 extra summer tires and 4 studded winters on the stock celica rims
Motor, suspension, tires/rims and interior in excellent condition. Minor denting on the passenger door (only visible if the sun reflects off of it, shown in pictures)
bleach
Re: Looking at Buying a 1991 Celica GT-Four ST185
Postby underscore » Sun Nov 03, 2013 12:49 am
I think technically the doors are compatible, but the 185 door has extra reinforcements and helps to stiffen the chassis.
Postby bleach » Sun Nov 03, 2013 1:09 am
Ok, Good thing I have a line on a Alltrac/GT-four door for $150. (I know of a few normal Celica around with cheaper doors.)
Nothing really to worries about with these cars, how is getting parts for it?
Thanks.
bleach
Postby MWP » Mon Nov 04, 2013 2:39 pm
underscore wrote:I think technically the doors are compatible, but the 185 door has extra reinforcements and helps to stiffen the chassis.
You sure about this?
It doesnt sound like something Toyota would do.
[edit]
Just looked up 184 vs 185 doors in the EPCs, there are no differences.
Even narrow-body doors are identical to wide-body doors.
Postby bleach » Tue Nov 05, 2013 2:29 am
Ok, thank you. sounds like for the lack of reply's there are very few common problems with this car.
bleach
Postby underscore » Tue Nov 05, 2013 3:38 pm
I'm getting the 182, 183 and 185 having the same subassembly and door skin, but not the 184 when I look in the EPC. If the dents are minor I wouldn't bother changing the door out just yet anyways, I'd wait and see what else the car might need first.
I spoke to the mechanic that did all the work to the car while my friend owned it, it has a Comp flywheel and clutch and it had all the timing work done at the same time about a year and a half ago. It's also had all the suspension/hubs/control arms/etc replaced on the passenger side due to a run in with a curb a few years back.
Postby bleach » Sat Jan 25, 2014 5:06 am
Well I maybe buying this car for $4000, what do you guy's think good or bad? He did have it listed at $6000.
I can't help to think it would be a good sleeper.
bleach
Postby pintoBC_3sgte » Sat Jan 25, 2014 5:24 am
buy it! you in the okanagan area?
pintoBC_3sgte
Postby bleach » Sat Jan 25, 2014 5:32 am
pintoBC_5sfte wrote:buy it! you in the okanagan area?
No, somewhere else. :P It's MINE, I will have it check out first then I am going to grab it. should be a fun car.
bleach
Postby bleach » Sun Jan 26, 2014 3:10 am
The dent will be hard for me to pull, but the frame is fine. (it's a wide glancing dent. that the best way I can described it. )
On Thursday we are going to put it on a hoist, it the rust is minor. I am going to buy it.
bleach
Return to GT Four Chat
