Turbo Question
Turbo Question
Postby MrMcQuacker » Wed Dec 04, 2013 1:29 am
Hello, So my question is I will eventually upgrade my ct26 to a to4e 57trim sooner or later and I can not seem to find a straight answer from researching. Should I or should I not Clip the exhaust wheel? also I have read that people have done 10-15degree clips. If I do go the route of clipping it, then I will go with the 10Degree clip.
Thank You for your input.
MrMcQuacker
Re: Turbo Question
Postby Shaggz00 » Wed Dec 04, 2013 2:02 am
What is the rest of your engine setup? That's an awfully big turbo to run on a 2.0 liter. I speak from experience, you will have some major lag. Then again, if you're going for high HP, it might be just the ticket. Let's start there, and pick the proper turbo setup for you.
-Avi-
Shaggz00
Re: Turbo Question
Postby MrMcQuacker » Wed Dec 04, 2013 4:14 pm
I have a 3gen 3sgte in my st165. I have a full 3" exhaust and a aem ems4. I have it but not installed. Also got arp heat studs just sitting around have not installed those either. My power goals are about 350awhp.
MrMcQuacker
Re: Turbo Question
Postby MrMcQuacker » Fri Dec 06, 2013 6:02 am
300awhp for now will suffice for a while though.
MrMcQuacker
Return to GT Four Chat
