Help Please :(
Help Please :(
Postby MrMcQuacker » Fri Feb 14, 2014 12:07 am
I just did a spark plug change and noticed that my 2 and 3 spark plugs were full of oil. Car drives fine, I researched a bit but could not find anything specific for out motors. Do I just change out my valve cover gasket? I have a 3gen 3sgte if that matters.
MrMcQuacker
Re: Help Please :(
Postby MrMcQuacker » Fri Feb 14, 2014 12:09 am
Also from the looks of it inside the hole. It looks like oil is seeping through from above the spark plug not after.
MrMcQuacker
Re: Help Please :(
Postby WideFNopen » Fri Feb 14, 2014 12:21 am
Try a new valve cover gasket set. There are 6 points where fipk is used so pick up a tube of that when you order your gaskets.
https://www.facebook.com/peakcityrally
http://cdn.makeagif.com/media/1-12-2015/ZMp5Gn.gif
WideFNopen
Re: Help Please :(
Postby bobtherider123 » Fri Feb 14, 2014 1:43 am
the metal spark plug tubes unscrew from the head and can leak. remove them, rtv the threads and screw them back in. also the round gaskets on the valve cover tend to leak as well so change those.
bobtherider123
Re: Help Please :(
Postby MrMcQuacker » Sat Feb 15, 2014 4:53 am
Cool, Thank you guys. I have looked at a few and noticed twosrus a set for decent price. It says that st185 Valve Cover Gasket's "Might" work on st205. Can anyone confirm this before I buy please?
MrMcQuacker
Re: Help Please :(
Postby MrMcQuacker » Mon Feb 17, 2014 6:31 pm
Bump Please I need to know so I can buy it.
MrMcQuacker
Re: Help Please :(
Postby phattyduck » Tue Feb 18, 2014 4:36 pm
ST185 gasket kit won't work on the ST205. Compare:
ST205:
ST185:
You should be able to get what you need from kbox pretty easily:
http://www.kbox.ca/catalog/product_info ... cts_id=429
'99 4Runner SR5 4WD 5VZ-FE
phattyduck
Return to GT Four Chat
