Questions about ST165s
Postby 1988tetunum » Fri Nov 13, 2015 5:56 pm
So I'm going to purchase an ST165 (Finally found one!) but it was damaged in a hit and run, the quarterpanel got squished (as well as the molding on the quarterpanel, I'll post a picture) So I have these questions:
Q1: Is the molding around the ST165 the same as the FWD models?
Q2: Does anyone have a picture of an AWD ST165 with the molding deleted? (Doubt I'll take this route, but figured I would ask)
Q3: Are the quarterpanels on the AWD and FWD models the same?
I want to get a quarterpanel to replace this ruined one (Weld it on) Do I need one from the AWD models? or do the GTS FWD ones match?
1988tetunum
Re: Questions about ST165s
Postby Nate165 » Fri Nov 13, 2015 6:34 pm
I'm not to sure if they are the same for models, but i know this is a pretty boxy car,so I would imagine it would be to hard to get some metal and shape it.???
Nate165
Postby Ghooble » Fri Nov 13, 2015 8:10 pm
The lower trim (skirts and front air dam) are different on GT4's compared to the others.
This is what a GTS fender looks like on my ST165.
http://imgur.com/IgOD0Cl
I imagine the rear looks the same.
Ghooble
Postby underscore » Fri Nov 13, 2015 9:09 pm
It looks like the lower trim is intact, so you *should* be able to make the FWD fender work.
Postby Ghooble » Fri Nov 13, 2015 9:20 pm
underscore wrote:It looks like the lower trim is intact, so you *should* be able to make the FWD fender work.
I don't know how easy it is to attach though.
Looking at mine I'm going to have to make new brackets (they're rusted to shiiiiiit) then attach those, then attach the trim to that.
Orrrr I can get my original fender fixed..which I'm gonna try to do. :|
Ghooble
Postby 1988tetunum » Fri Nov 13, 2015 11:38 pm
So I should be able to cut the ruined quarterpanel out, cut a good one out of a FWD model, weld it in, and then re-use my trim?
1988tetunum
Postby Bempa » Sat Nov 14, 2015 6:25 pm
You would need to make the holes for the fasteners. Otherwise it´s the same
AE92 4age 20v Engine rebuilding
KE70 4age 16v In progress
ST165 3sgte Brum Brum
ADT251 2ad-fhv Daily
AE92 4age 16v Bigport What to do with this one?
ACM20 1az-fe Wife´s daily
Instagram Benny_Gustavson
Bempa
Postby r-town » Sun Nov 15, 2015 7:27 am
This guys has the same hit on the passenger side, i thought this was the car you were buying lol or is it?
viewtopic.php?f=44&t=50910
r-town
Postby 1988tetunum » Sun Nov 15, 2015 9:30 am
r-town wrote:This guys has the same hit on the passenger side, i thought this was the car you were buying lol or is it?
Deeeefffinitely different, mine is nowhere near that bad
1988tetunum
Return to GT Four Chat
