Steel Head Gasket: Good Choice?
Postby Il_Barone » Wed Jan 20, 2016 2:25 pm
Hi :)
I have to rebuild an original st185 3sgte engine, i found a complete gasket kit with the steel head gasket.
Is it better than the original one?
Thank you :)
Il_Barone
Re: Steel Head Gasket: Good Choice?
Postby quieter » Wed Jan 20, 2016 3:14 pm
hi! a steel headgasket is alot better than the graphite one and is always one of the first recommended modification on a 1st and 2nd gen 3sgte modification along with ARP headstuds (when opening then engine up). it's also recommended to change it to a steel headgasket if you ever want to raise your boost levels.
2011 BMW 535xi M pack (daily)
-Simon
quieter
Postby Il_Barone » Wed Jan 20, 2016 3:45 pm
quieter wrote:hi! a steel headgasket is alot better than the graphite one and is always one of the first recommended modification on a 1st and 2nd gen 3sgte modification along with ARP headstuds (when opening then engine up). it's also recommended to change it to a steel headgasket if you ever want to raise your boost levels.
Hi quieter :)
Which particularities have the ARP headstuds? :)
Thanks
Il_Barone
Postby ___Scott___ » Wed Jan 20, 2016 4:21 pm
I've recently been looking for a good source for ARP head studs and this is the best option I've found so far:
http://www.koracing.net/viewproduct.php ... roduct=237
If anyone knows of a better source, please share.
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby quieter » Wed Jan 20, 2016 5:30 pm
they are reputed and it isnt recommended to re-use your headstuds because they probably stretched in their lifetime and can warp with the heat
-Simon
quieter
Postby Il_Barone » Wed Jan 20, 2016 8:21 pm
quieter wrote:they are reputed and it isnt recommended to re-use your headstuds because they probably stretched in their lifetime and can warp with the heat
Understood :)
I've seen that ARP produces also the main studs kit too...
Am i obliged to replace those too?
Thanks again :)
Il_Barone
Postby Gt4grey » Wed Jan 20, 2016 9:34 pm
I've just removed the cylinder head from st185, the gasket had turned into papier mache, definitely be replacing with cometic metal gasket.
Gt4grey
Postby aus jd 2703 » Fri Jan 22, 2016 5:29 am
Be aware with the cometic the now offer a gen 2 and gen 3 model. Order the correct one to suit your engine.
aus jd 2703
Postby underscore » Fri Jan 22, 2016 5:35 am
Cometic makes a gen 3? Good to know, as I recall the OEM gen 3 has some improvements over the gen 2.
Postby aus jd 2703 » Fri Jan 22, 2016 9:18 am
From what I see it encourages more flow through the head and not so much the cylinders
aus jd 2703
Postby Il_Barone » Fri Jan 22, 2016 11:07 am
I'm looking on the Cometic website.
There are different sizes of thickness and two different models of the MLS Head Gasket.
I have to fit four 86.5 pistons, do you know the exact thickness and the part number of the cometic gasket that i have to buy? :)
Il_Barone
Postby underscore » Fri Jan 22, 2016 3:11 pm
There's a comparison of the two somewhere on the net, I believe some of the cooling holes were made slightly smaller on the gen 3 to force more coolant to areas that needed it more (presumably to prevent the cyl 2/3 wall cracking).
As far as thickness goes it depends on the amount of material shaved from the head and block, if you have any doubts I'd contact Cometic directly and ask them.
Postby Il_Barone » Wed Mar 23, 2016 10:53 am
Just bought this kit :D
Il_Barone
Postby Gt4grey » Tue Apr 05, 2016 6:20 am
The metal gasket is by far the better choice, original gaskets turn to papier-mâché.
Gt4grey
Postby Akihero » Tue Apr 05, 2016 12:54 pm
but can you just swap the head gasket or do you need to deck and shave i have a jdm gen 2 with 45k miles and ive been trying to figure out if i can just swap it out or do i have to do more stuff. thats the one i have.
http://www.atsracing.net/Parts/Details/E-HEADGASKET
MLS = Multi Layered Steel Available for 2nd Gen 3S-GTE applications in 1.2mm thickness. This is the head gasket of choice at ATS Racing.
Akihero
Return to GT Four Chat
