transfer case actuator
Re: transfer case actuator
Postby underscore » Fri Jan 29, 2016 6:20 pm
As I recall you can swap the cable speedo onto the 205 trans, I'm not sure about the 215. Someone could have swapped on a housing without the selector but I have no idea why, they only real way to be 100% sure of what you have is to open it up and start counting teeth.
Postby JDMSD1 » Fri Jan 29, 2016 7:05 pm
My RC trans has a selector.
The other trans I have does not.
JDMSD1
Postby JDMSD1 » Sat Jan 30, 2016 1:20 am
Yep has the vent and no actuator.
It's a st 205, based on the article.
JDMSD1
Postby Camshaft1987 » Wed Mar 16, 2016 10:33 am
its a 205 trans has the little vent hole next to the shift fork boot.... I was wandering what the hell that was for sweet.
Camshaft1987
Postby JDMSD1 » Wed Mar 16, 2016 12:54 pm
Yeah
JDMSD1
Postby AwdGte » Sun Mar 27, 2016 8:18 pm
Want to sell the RC trans? I need the selector switch to dyno
AwdGte
Postby JDMSD1 » Mon Mar 28, 2016 1:45 am
No sir.
It's in my car.
St 205 trans only for sale.
JDMSD1
Postby AwdGte » Mon Mar 28, 2016 2:36 am
I cannot switch to 2wd with that, correct? What about if I used a different center differential with it? Does it have an electronic speedometer output or a mechanical?
Where are you located and what do you want for it? Do you have an ST205 rear?
JDMSD1 wrote:No sir.
It's in my car.
AwdGte
Postby JDMSD1 » Mon Mar 28, 2016 10:29 am
Has cable speedo,you can use your sensor or cable.
No rear.
St205 trans everyone wants.look in to it.i would use it,but I am trying the RC out.
$500,transmission is in escondido ca
Trans will be in tuscon in a month or so.you can pick up either location.
(619)seven o four,4999
JDMSD1
Return to GT Four Chat
