What else should I replace while doing the clutch?
Postby Covenant239 » Tue Feb 02, 2016 10:41 pm
I'm doing the Clutch and flywheel on my ST185. what else should I replace while I'm in the area with the transmission off. I know I'm going to do the Rear main seal, what else?
Covenant239
Re: What else should I replace while doing the clutch?
Postby yyonline » Wed Feb 03, 2016 7:39 am
Axle and prop shaft seals would be good to do while the transmission is out. On most cars the transmission input shaft seal is recommended, but that's not changeable on this transmission without opening up the transmission case.
Given that you have to pull the engine out to do this job, I'd consider doing a timing belt, cam/crank seals, and replacing the "hoses from hell". All of that is so much easier to access with the engine out of the car.
yyonline
Postby 94 MR2 Turbo » Wed Feb 03, 2016 8:04 am
You don't have to pull the engine.. It just takes some finesse. I just did mine just change out your rear main and put In a good hassle free clutch. Also take out the control are it frees up some space. It still sucks either way.
94 MR2 Turbo
Postby Covenant239 » Wed Feb 03, 2016 11:48 pm
ok, Thanks for the input.
Covenant239
Postby CTechBlueDragon » Thu Feb 04, 2016 3:16 pm
Replace the engine with a Caldina engine! HAHA
No seriously though, do it. =D
CTechBlueDragon
Images: 51
Return to GT Four Chat
