Axle nut broke off. Need to locate driver side front axle.
Re: Axle nut broke off. Need to locate driver side front axl
Postby Kurt_st185_gt4 » Tue Jan 24, 2017 12:48 am
Well the price on rock auto is just $80 plus they have the fastest shipping even to me and I'm in Germany.
Kurt_st185_gt4
Postby awdmofo » Fri Jan 27, 2017 7:36 pm
FC Zach wrote:
awdmofo wrote:should do both sides even though only one is messed up?? what are you guys paying for two rebuilt ST185 front axels?
If you have the same luck as I had with mine. . You'll replace only what's necessary but shortly afterwards you'll have to replace the other side :( Even with that said, I wouldn't worry with the opposite side unless it's questionable. I got three (yes three. . . one was defective :x ) from O'reillys for less than $50 each.
http://www.oreillyauto.com/site/c/search/CV+Half+Shaft+!s!+Axle+Shaft/01424/C0362.oap?year=1992&make=Toyota&model=Celica&vi=1274194&utm_medium=Yext&utm_content=ReplacementParts&utm_campaign=Catalog&utm_source=Header
Yea I think just new boots and have a local shop rebuild would be fine. no need to rip it out again if I already have it appart.
2013 Camaro LS 6-sp (daily)
2005 Yamaha R6 (sold)
2001 Spider (sold)
1990 alltrac (sold)
1991 MR2 turbo x2 (Sold)
awdmofo
Postby Kurt_st185_gt4 » Fri Jan 27, 2017 9:02 pm
If you haven't fixed the snapped side yet it's worth it to measure the outer diameter of the bearing seat int the hub and the inner diameter of the bearing seat on the knuckle just to make sure they are within tolerance and not shaved down. Take it from me. I went through 3 bearings in two months.
Kurt_st185_gt4
Postby FC Zach » Fri Feb 10, 2017 4:57 am
On the topic of axle availability and their prices. . . Can anyone tell me what would make one of these readily available axles $300?!
Occasionally I search fleaBay for hard-to-find pieces I have yet to find here and have seen these for a while now, at that price I wouldn't be surprised if they never sell.
http://www.ebay.com/itm/1990-1993-Toyta-Celica-Alltrac-ST185-AWD-Axle-Shaft-Assembly-NEW-/142188194612?fits=Model%3ACelica&hash=item211b13ab34:g:UkoAAOSwtnpXk3KD&vxp=mtr
1992 Toyota Celica AllTrac
1987 Mazda RX7 Sport
FC Zach
Images: 9
Postby mx6er2587 » Fri Feb 10, 2017 12:25 pm
should ask the seller. He is on this site. No clue what the difference between this and a rock auto axle is though.
mx6er2587
Postby FC Zach » Fri Feb 10, 2017 12:53 pm
mx6er2587 wrote:should ask the seller. He is on this site. No clue what the difference between this and a rock auto axle is though.
Eh, not that important. . Just wondered if anyone that knew could enlighten me since that price seemed a little inflated.
FC Zach
Images: 9
Postby celicast184 » Mon May 15, 2017 3:41 am
Jus so you guys know, the 1988 camry v6 outer axles are the same as the st185 units. U can ask autozone/pepboys/orileys and order for that yr. there sould be plenty of these!
I <3 MY ST214
celicast184
Return to GT Four Chat
