Excess piping
Excess piping
Postby my3sgte » Fri Apr 28, 2017 1:48 am
Hey all! Been awhile! Guess basically I am trying to figure out if there are any write ups on deleting some vacuum lines on the 3sgte? Or if anyone has some suggestions?
Thanks!
my3sgte
Re: Excess piping
Postby Corey » Fri Apr 28, 2017 11:00 pm
If your car has EGR, deleting that will clear up some vacuum lines.
Also, if you delete the TVIS by replacing it with one of these : http://koracing.net/viewproduct.php?fol ... roduct=633
Deleting the TVIS will take many of the vacuum lines sitting behind the engine along with it.
While I was back there, I also removed the TVSV since I had installed a manual boost controller to replace it.
Corey
Images: 50
Re: Excess piping
Postby my3sgte » Sat Apr 29, 2017 12:51 am
Oh nice! Thank you appreciate the help! Knew egr but wasn't sure what else....
my3sgte
Re: Excess piping
Postby underscore » Sat Apr 29, 2017 3:51 pm
EGR and TVSV will clean up a lot, TVIS you'll want to keep if you're running stock 165 or 185 electronics. If you've got a heavily modified setup or are running 205 or newer electronics you don't need it.
Return to GT Four Chat
