My 1991 GT-FOUR RC #1172/5000 st185 in Oregon
Postby OregonGT4RC » Wed May 10, 2017 7:37 pm
Wanted to say hello to everyone. Here are a few pictures of my 1991 GT4 RC that I am restoring/modding in Oregon. I have had to clean up quite a few issues that the previous owner in Japan happened to have done to the car.
Issues fixed:
1. High pressure P/S hose was destroyed, fixed that and had to replace all the drivers side bushings as the fluid has deteriorated all of them. Went to White Line Poly bushings.
2. Drivers and passenger pillar trim was ripped. Sourced the proper fabric and re-rapped the pillars back to OE specs
3. Steering wheel was an Ebay one with a Momo Toyota authentic horn button. Sourced and replaced with proper Momo Corse polished one
4. Starbo Turbo Timer was half assed mounted. Re-located it to the top of the dash for easier viewing,
6. Shift boot was destroyed. De-stitched the OE one and sewed up myself a good black leather one.
7. Check engine light was on due to a bad WTA/IC sensor being inop. Cut and fused together to keep the car thinking its not inop. I do check fluids before every trip
8. The lower grill mesh was destroyed so I sourced an OEM one and replaced
Pieces added:
1. AEM True Boost gauge/controller
2. Sparco Terra wheels with Dunlop Dirreza tires
3. Momo Corse polished wheel
4. BC coilovers (Will be here friday)
5. Compomotive TH1781 wheels
6. Sparco Terra wheels
7. 25mm rear spacers H&R
8. Whilte line poly bushings up front
9. BRD poly shifter bushings
10. GT4-Play rear diff hanger poly bushings
much more to come. Onto the pictures
OregonGT4RC
Re: My 1991 GT-FOUR RC #1172/5000 st185 in Oregon
Postby underscore » Wed May 10, 2017 9:59 pm
Welcome! Where did you source the lower grill mesh? Mine is MIA.
Postby pintoBC_3sgte » Wed May 10, 2017 10:28 pm
Wow! Looks awesome!
pintoBC_3sgte
Postby OregonGT4RC » Wed May 10, 2017 11:24 pm
I actually sourced it from Yahoo Auctions Japan. I do a lot of business with a shop called EP Importers that imports Japanese car stuff.
Thank you sir!
OregonGT4RC
Postby Fugaku » Thu May 10, 2018 2:10 am
What are the specs for the Sparco wheels? I've been looking at getting them too, but TireRack is always out of stock for this car. Maybe I'll get one for a BRZ or something and put spacers on.
Fugaku
Postby GT4times2 » Fri May 11, 2018 5:50 am
Welcome to the community!! I think I've seen this car on Youtube and IG, if you're the same guy. Nice to see you here. Love that car. My favorite color ST185. Keep up the great work.
Frantz
12 Toyota Sienna LE
12 Toyota Camry SE
90 ST185 Gen4
88 ST165 Gen3-The works
89 ST165 Gen4-on the way
GT4times2
Return to GT Four Chat
