ST205 Wiring Diagram
discoinferno218
New member
Alright guys, I have been looking everywhere online and I cannot find an ST205 wiring diagram for the life of me. The one at http://www.celicatech.com/bgbonline/#6th gives me a 404 error. I need the diagram to start working on the harness for my Corolla 3sgte swap I am doing. Any help would be appreciated. At this point I would go for either the actual book or the PDF.
FC Zach
Active member
I found that here: http://www.gtfours.co.uk/what/ecu_pinout/205/ecu_pinout.htm
Which was in this thread: http://www.alltrac.net/phpBB2/viewtopic.php?t=34254
discoinferno218
New member
FC Zach":1ag1ui6o said:
Thanks. This is a lot better than the half translated one I had. Too bad there is no translated full wiring diagram as far as I can tell. I doubt a Toyota Dealer will have one but I guess I can try them too. Anyone know by change if a MR2 3sgte harness will fit? Just need the engine portion of it, and the fuse box.
aus jd 2703
New member
discoinferno218":3848fm3y said:
aus jd 2703":3848fm3y said:
http://gt4.mwp.id.au
Great source
Yup I found all the other books I needed on there. Unfortunately there is no complete wiring diagram.
thought there was a 205 diagram in the chassis part, its all i used for my 205 swap...
Top
