Gen 3 tranny speedometer conversion mechanical to electrical
Postby k_trac » Tue Apr 05, 2005 9:13 pm
Im putting a ST205 engine / tranny into my 185. I need to know what I have to do to get my mechanical speedometer to work. I still have my mechanical sensor, and it doesnt look anything like the electrical one. I also do have the ST205 cluster, dont know if that would work, or if Id even want to use it. I know some other people have used the 205 tranny before.
Are the 92 or 93 cluster electrical? Mines a 90....
Any help would be apreciated.
Thank you!
The Screamer - '90 Red Alltrac - ST205 swap, 3" MP, 3" catback, intake, spec III clutch - FOR SALE $7000
The Sipper - '92 VW Jetta EcoDiesel
You scratched my CD!!!
k_trac
Postby InitialD93 » Wed Apr 06, 2005 4:22 am
fitting the 205 cluster is prolly gona be ur best bet... i dont know of any way to make a mechanical speedo electronic...
perhapse you colu gut the stock speedo spot and install a large Autometer electronic one... kinda like chris did with his boost and knock guages :shrug:
Dustin
1990 All Trac w/ RC bumper, converted to 93
^^^ Old project about to start a new life ^^^
InitialD93
Postby CMS-GT4 » Wed Apr 06, 2005 1:53 pm
Check gt4oc.com and the gt4 yahoo groups. I will have to do this myself. There is a simple conversion to do, but I am not sure what it is.
Good luck, and keep us posted.
Postby LechacZ » Wed Apr 06, 2005 2:11 pm
As I PM'd you, I removed the whole 205 speedo assembly from the tranny and put the 185 in it's place. I think it's held down to the tranny with one (12mm socket) bolt.
Les
ST-205
Ontario, Canada
LechacZ
Postby Austen_gt4 » Wed Apr 06, 2005 9:06 pm
he is correct ^^.. take it out and replace it with the one from the 185..
2006-DURAMAX RaPeVaN
2008-RUCKUS
2004-IS300
1993-MR2T X 2
1992-GT4
1991-SPEC MIATA
LOTUS 7 (in progress)
Austen_gt4
Postby CMS-GT4 » Wed Apr 06, 2005 9:08 pm
Thanks, thats easy as pie.
Postby k_trac » Wed Apr 06, 2005 11:38 pm
Ya, easy as pie this!!!!!
These are the two sensors, obviously, the one with all the gear is the electrical one. I dont have the 185 tranny anymore, so I dont know if there is something that I forgot to take off when it went.
k_trac
Postby LechacZ » Thu Apr 07, 2005 12:39 pm
well, u really should source out a 185 speed sensor if you want the peedo to work
Les
ST-205
Ontario, Canada
LechacZ
Postby Griffin » Thu Apr 07, 2005 7:11 pm
k_trac wrote:Ya, easy as pie this!!!!!
There is another part to the 185 speedo that actually goes into the tranny and houses the gear and gear shaft to hook up to the part in the picture. It should be a direct replacement for the ST205 peice. If memory serves it was not too expensive when I replaced mine (my gear was worn out)
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby 5speedGT4 » Wed May 04, 2005 1:49 pm
yea just take everything out and swap the parts to make it work... its pie!
i had to do the same sort of thing on my 185 tranny in my 165
Andrew
ST165<----Sold
5speedGT4
Postby k_trac » Wed Jun 01, 2005 12:16 am
Here is another picture of my dilema, just so you know Im not crazy-
k_trac
Re: Gen 3 tranny speedometer conversion mechanical to electrical
Postby soarer.jzz30 » Wed Jun 08, 2011 3:01 am
where is the piece from the 185 that has the gear on the end?? Oh well... time again to get out the angle grinder. :doh: :doh:
soarer.jzz30
Postby k_trac » Wed Jun 08, 2011 9:27 am
Wow, this is an old post, but still subscribed. I sold that car like 4 years ago.
Anyhow, I do still remember this.....there is a peice missing that I left on the 185 tranny and didnt realize it. It was just a drive gear that threaded into the trans. Im pretty sure I sourced one from a 184 in the junkyard, easy fix.
k_trac
Return to GT Four Chat
