Need info on my St205 parts.....
Postby martin » Sun May 15, 2005 3:25 pm
Hi,
Ok, i have an ST205 motor with the electronics. I noticed my part #'s are a little diffrent from others. For example my map sensor has a higher #, etc.
This is my ecu # 89661-2B840
Map sensor .....89420-20310
Ok, i also have a white box computer which i have no idea what it does. It has 3 connectors going into it. I think the connector slots have a orange color. The part # for this thing is 88650-2B310. Anyone know what it is and what it does?
thanks,
Martin
martin
Postby Gary » Sun May 15, 2005 4:32 pm
89420-20310 is listed as a ST205 MAP sensor on a Japanese site.
And 89661-2B840 is the ST205 ECU according to imoc.co.uk
You can use this site to translate
http://world.altavista.com/tr
93 ST185
Gary
Postby martin » Sun May 15, 2005 6:27 pm
thanks Gary.
Do you or anyone else know what the other part # i have listed might be?
Does the ST205 motor have a sepporate ecu for the intercooler?
I saw on a website that the st185 has a orange relay box under the glove box for the IC water level sensor, but i have not found such a part under the dash on my st205 clip.
Martn
89 MR2 MK1.5
martin
Postby Gary » Sun May 15, 2005 6:46 pm
martin wrote:Does the ST205 motor have a sepporate ecu for the intercooler?
No.
martin wrote:I saw on a website that the st185 has a orange relay box under the glove box for the IC water level sensor, but i have not found such a part under the dash on my st205 clip.
You meant ST185RC?. A normal ST185 has A/A IC.
Still, I have never heard of a separate ECU for IC.
The water level sensor is in the intercooler.
Both ST185RC and ST205 have water level sensor signal
wire (LEV) from the intercooler to the main ECU.
There is no separated IC ECU.
93 ST185
Gary
Postby martin » Sun May 15, 2005 9:26 pm
Thanks Gary.
sorry, one more question....
I'm using all the oem electronics. I'm not using the oem pump for the ic. Will i have the check engine light cone on with a code 54 and can i do a quick wire splice to fool the ecu that there is not a problem with the IC water level. etc.
Martin
89 MR2 MK1.5
martin
Postby Gary » Sun May 15, 2005 9:55 pm
I think I may be wrong about the seperated ECU for IC in ST185RC.
There was a guy said that it is written in the BGB.
I'll try to find out more about that. :shrug:
93 ST185
Gary
Postby Gary » Sun May 15, 2005 10:15 pm
By the way, about the code 54, you can try one of these methods
ST165 intercooler pump removal
If you remove the pump motor you will get a code# 54. (bad IC pump motor)
If you remove the IC itself you also will get a code# 54. (low IC coolant)
The code may limit your boost.
The wire from the loom to the IC float needs to be jumped Just connect one to the other, solves low coolant signal.
The wires that go to the pump need a resistor from Radio Shack or some other electronic store. I used a 20w 8ohm resistor. You just connect the wires from the loom that goes to the pump to the resistor . One wire to one end of resistor and the other wire to the other end, positive or negative doesn't matter. Remember resistors get hot so it’s a good idea to attach it in some manner to metal.
Or do the IC pump constant run
http://homepage.ntlworld.com/celicagt4/ ... nstant.htm
93 ST185
Gary
Postby martin » Mon May 16, 2005 7:32 pm
thanks, now i know what needs to be done.
btw; the link that you posted above, that is where i have seen the orange box under the glove box, so i thought that it had to be under the glove box of my st205 clip too.... but now i know better. LOL
thanks,
Martin
89 MR2 MK1.5
martin
Return to GT Four Chat
