Forum Idle Logout time
Find out what's happening
Postby WarTowels » Wed Feb 29, 2012 2:09 pm
I find myself getting constantly logged out do to what I think are really short periods of being idle.
I've been logged out several times while writing detailed posts. I write and write and go to post, and oh no, I've been on the same page for 3 minutes better log me out. =)
I assume there is a setting within phpBB where you can set the idle time before logout, can we increase that? Or better yet, it should be based on your session (cookie). If my window is open and I'm logged in, don't log me out until I either logout myself (which is never) or log me out when I close the browser- ideally.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Re: Forum Idle Logout time
Postby pwadm » Wed Feb 29, 2012 6:04 pm
Hi Towels,
The current timout is set to 1 hour. We can increase the value, but what would really fix your problem is checking the 'Log me on automatically each visit' checkbox on the login screen when you type your name/password.
The software would automatically log you in, even if you are in the middle of writing a post. I use this option, and I am logged in for days. This functionality is based on a persistent cookie saved in your browser. You wouldn't want to use on a public terminal, but it can be very useful on your own PC.
pwadm
Images: 8
Postby athousandleaves » Wed Feb 29, 2012 7:15 pm
I've noticed this too; what was the previous logout time?
I do keep the autologin checked but it's a little scary when you've gone to make a post and it asks you to login again.
I've also been getting an "internal server error 500" quite a bit recently and have made it a habit to copy my entire post to the clipboard before hitting submit. In fact, I just saved this post from that error !!! @_@
1992 Red GT-FOUR RC 626•1800
1992 White turbo4WD
athousandleaves
Postby pwadm » Wed Feb 29, 2012 7:54 pm
The idle time was always set to 1 hour. I will investigate the 500 error...need to look into the logs.
pwadm
Images: 8
Postby CMS-GT4 » Wed Feb 29, 2012 7:57 pm
Mine logs out on the computer every time I check the forum on my phone. I check always log me in each time. The phone stays logged in however.
Postby WarTowels » Wed Feb 29, 2012 8:29 pm
Hmmm. I don't have the auto login checked, that's never seemed to work for me.
I'm using a private terminal and I'm definitely not writing for an hour. So I'm not sure what's going on.
If I spend upwards of 5 minutes writing a post, I more often than not get asked to log back in and then usually I can force the browser to go back and get my post, but I've lost several as well.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby pwadm » Wed Feb 29, 2012 9:45 pm
The problem may be related to your ISP changing the IP from which your computer makes requests. The forum software validates the session based on the IP, and if the request comes from a different one it invalidates the session.
Since it may be the root of your session timeout problems, I disabled the feature. Lets see if it helps.
pwadm
Images: 8
Postby WarTowels » Thu Mar 01, 2012 1:47 am
My IP should be staying relatively the same. I do clear all cookies on browser exit though, so that might have something to do with it if cookies are involved. But that would only relate the auto login.
I'm not sure why mid writing posts I get logged out. I'll report back and see if anything has changed now.
-Towels
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby toayoztan » Thu Mar 01, 2012 3:51 am
To somewhat be ontopic, I now hit ctrl+A (to highlight all) and ctrl+c to copy, before submitting a large post...just in case :D
If something goes awry, I just make a new post, then paste it.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby WarTowels » Thu Mar 01, 2012 5:16 am
I try and do the same as well, but every now and then I forget.
2003 S2000
1985 300TD
WarTowels
Gold GTfour God
Postby CMS-GT4 » Fri Nov 14, 2014 8:28 pm
Is there any reason this might be an issue anymore? I get logged out all the time now.
Postby pwadm » Fri Nov 14, 2014 9:39 pm
We haven't changed the settings in a long time. Do you check the autologin option when you login?
pwadm
Images: 8
Postby MWP » Sun Nov 16, 2014 3:43 am
CMS-GT4 wrote:Is there any reason this might be an issue anymore? I get logged out all the time now.
Yup, same here (using Chrome).
I pretty much have to re-login every time.
Although i'm wondering if it has something to do with also having the forum open in a tab on my phone (Chrome on Android).
Postby pwadm » Tue Nov 18, 2014 1:38 pm
I am not sure if having sessions in two Chrome browsers at the same time would log you out. I tried doing it with two different browsers (Chrome, Firefox) and the session was maintained on both. Chrome allows you to login to the browser, which then synchronizes some settings (sessions?) - maybe try login to Chrome and see if that helps.
I checked again, and all settings that would restrict the 'autologin' in some ways are turned off. If your ISP changes your IP address for example you should still remain logged in. The only thing that would log you out is a removal of a browser cookie, but this can only be done manually by going to Chrome options. Puzzling...
pwadm
Images: 8
Return to Forum News
