My hack-o-licious FMIC project
Postby gearhead313 » Wed Aug 16, 2006 2:15 pm
Hopefully this info will be useful to someone when they tackle a full custom FMIC project such as this one.
The intercooler I started with: 31x12x3 end to end with a 23.5" actual core width. 3" inlet/outlets.
This is what we start with:
Bumper comes off. Clips on the side and 2 main support bolts (17mm) from underneath through the frame rails. I snapped one and had to torch the top welded nut off and pound it out that way. It REALLY sucked:
Close up of what we need to start getting out of the way:
Snip the fan off with side cutters and the I/C radiator comes off with 4 12mm. Horns also removed:
Lets do a test fit.... YES!!!:
The bumper rebar comes off of the bumper cover. I broke 80% of all the bolts that I tried to take off. I'll probably have to drill out the broken studs and put nuts and bolts in it. 10mm accross the top and on hte underside of the center opening and side openings.
Once off, I decided to give myself as much room as possible (also basing that on the top of the cooler being flush with the top of the frame rails on my first mockup). I used a torch to hack the meat out of it to what you see here:
Now, topside I removed the battery, pushed hte harness out of the way and unbolted the top mount. This is making room to get to all the stock i/c lines and pump:
mmmm IHI:
There is that raskulley water pump!:
Here is a top view of where the lines bolt to the block/trans through the starter. They looked like they would SUCK to remove, so i got the sawzall in there and hacked the tabs off:
No top mount... getting cleaner!:
I/C Pump from underneath, you can see the 12mm bolts you need to tackle:
Bolts removed, then the bracket on the side is held on with 3 10mm:
No more I/C water lines:
View from the side:
where'd my egr port go???:
Bumper bar installed... yikes:
Dry fit the cover and mark where to cut:
Basicly you cut the whole thing apart :tear: :
Unbolt the P/S cooler line and shove it behind the center support:
Placing the FMIC:
Dry fit with the newly hacked bumper:
Top mounting tabs for the cooler:
My uber goober welds:
Thats all the progress so far. I've been busy with actual "work", so hopefully soon I'll get the piping figured out and get some stuff ordered up! MORE FUN TO COME!!
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby v3rs3 » Wed Aug 16, 2006 3:24 pm
That is an awesome write up. Thanks alot that will definitely help me down the line as I plan to go to a FMIC setup by winter.
'88 Toyota Celica Alltrac
v3rs3
Postby gearhead313 » Wed Aug 16, 2006 3:31 pm
No prob. I wasn't sure how many people would actually cut there alltrac's up this much, but either way I'm not the sane'est contestant on death row either. 8) :twisted:
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
Postby Celica Turbo » Wed Aug 16, 2006 4:08 pm
Hello
FMIC looks perfect, but you need a cleaner engine :shoots:
Celica Turbo
Celica Turbo
Postby 1BADGT4 » Wed Aug 16, 2006 9:18 pm
v3rs3 wrote:That is an awesome write up. Thanks alot that will definitely help me down the line as I plan to go to a FMIC setup by winter.
+1 THANK YOU for this write-up! I'm sure one day I'll get around to tackle this tough job.
One thing that kinda bugs me is that, you gotta hack off the buttom part of the bumper :(.
Since you hacked a part of the bumper reinforcment off, have you thought about welding a plate to close the open reinforcment? and for structural integrity?
MODs - sticky please!
and time to throw some Coke-Cola on the batt acid. :twisted:
UT2 (SCW) Chan - Oakland, CA
04 Duc Monster DS
400BHP @ 20#, low 12s
1BADGT4
Postby theUNYTEDone » Thu Aug 17, 2006 4:57 am
i just drive better to make sure nothing hits me/ vice versa.
my bumper support's gone.
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby 1BADGT4 » Thu Aug 17, 2006 7:33 am
I wouldn't mind driving around without a bumper support. But that would ONLY be on the track. I couldn't see myself that ballys.
04 Duc Monster DS
1BADGT4
Postby theUNYTEDone » Thu Aug 17, 2006 7:56 am
1BADGT4 wrote:I wouldn't mind driving around without a bumper support. But that would ONLY be on the track. I couldn't see myself that ballys.
you don't need to be when people run away because you have a HUGE ASS front mount.
but seriously, i know i'm taking a risk...the bumper support's aluminum, too...lol. not to say my intercooler is replacing the bumper support...
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby gearhead313 » Thu Aug 17, 2006 12:23 pm
Ya, i know the motor is dirty, someday I'll get to scrubbing it. That battery is going in the trunk too BTW.
I didn't plan on doing anything about the support either. I just know that if something happens, god forbid, then the car is junk. I'll just do my best to play it safe... and if that one A-hole hits me, then i'll have 10 new alltracs anway :D
Oh ya, and I weighed that front support beam... 25lbs. That thing is heavy as HELL! I'll enjoy having some of that weight off the front of the car! ....well i guess some gets added back on with the gigantic fmic :P
here's another thing too. I originally planned on buying a cooler that wasn't as tall so that I could bolt it straight to the bumper beam and not have to hack it up. Whenever I went to go purchase that intercooler, I could get this one thats twice as tall for CHEAPER than my original one. I think im glad I went bigger :twisted: Maybe on my other alltrac I'll do a smaller one that is more simple to install.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
Postby Sifu » Fri Aug 18, 2006 3:08 pm
Holy shat that's looking good! Keep us posted!
BROKEN! BUT NOT BEATEN!
2005 Scion tC FW21
1985 AW11
1987 AW11
Sifu
Postby gearhead313 » Fri Aug 18, 2006 7:18 pm
Ran into a couple more couplers that I need, so had to make an order. I hate waiting :cry:
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
Postby Rick89GTS » Sat Aug 19, 2006 2:41 pm
Great write up with large-sized pics. Can't wait to see more :D
Rick89GTS
Postby Gary ST165 » Sun Aug 20, 2006 12:15 pm
great pics and write up.
:shock: however you should really plug the open inlet manifold and turbo outlet etc, to stop dirt & foreign objects getting in !!!.... other wise it may all end in :cry:
ST165 turbo 4WD
Gary ST165
Postby gearhead313 » Sun Aug 20, 2006 3:51 pm
Thanks guys... hopefully monday I'll get crackalackin on it.
Usually whenever i have my car sitting outside for a long period of time with intake pipes open, i'll seal them. This though is in my shop, not for long and the only worrys would be a little dirt. I'm not real worried about it. If it was a customers car though!!, thats a different story.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
Postby gearhead313 » Wed Aug 23, 2006 8:09 pm
Update:::
Got some more work done on the car.. actually its basicly done now, all i need to do is throw the rad in it and get the battery relocation kit in it, which i could do a write-up on as well if anyone wanted.
So here we go.
Starting in reverse "flow" order, I went from the throttle body back.
Luckily, i had an extra piece of piping laying around from a previous car that worked really well. 2.5" out to a 90* and then over to another 90*. I used the stock BOV section for the time being.
I used a Turbonetics 90* elbow I had laying around to head down the car.
It was a 15" section of exhaust pipe I had laying around to go down and then purchased a 2.5" 90* elbow coupler.
When I measured for the 180's, I found a few options but then came accross these ebay auctions:
http://cgi.ebay.com/2-5-45-180-304-Stai ... dZViewItem
I bought 2 and they worked PERFECT!....as you can see (I used aluminized, not stainless... im a cheap bastard)
FMIC all there
This is the passenger side now. You can notice that I had to wack the tow point off to make it work. I was too lazy to unbolt it and plus i have a whole other car to skank one off of if i wanted it back.
Using the extra pieces from those ebay pipes, I made two 45* pieces work to run up to the turbo. The one I welded b/c i was out of couplers!
Wide shot
All said and done, I had to hack the wastegate dump tube and route it close to the downpipe and back to avoid it coming in contact with the now charge pipe there. I used 1.5" 11ga. 180's i had laying around.
Another view. It worked out nice.
So now, I'm in the home stretch. I will probably wrap the header before im done and make a heat sheild for that charge pipe up top. I want my air charger to stay as cool as possible! As well as the battery relocate kit, i'm going to change my cooling fans around to see if I can get a more efficient setup. Oh ya, horns i'll have to stick on too.
Notice too, i'm still going to have a/c!!!
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
