Whats your engine bay look like?
Re: Whats your engine bay look like?
Postby gt4tified » Fri Sep 28, 2012 1:25 pm
^^^ when I saw the pink I was like, as we say here in Trinidad....LAWD FADDA!!!
gt4tified
Images: 5
Postby wakkjobb » Sun Sep 30, 2012 2:24 am
gt4tified wrote:
DudeMan wrote:Image
Sweet Jesus, that's a clean engine bay!
Fo sho'; this is a great example of why side-feeds are awesome. 8) 8) 8)
MFIC at Rainbows and Unicorns Fabwerkz :D
Old build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=27648
New build:
http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=42305
Go-Fast parts:
siliconeintakes.com
wakkjobb
Postby bmt » Sun Sep 30, 2012 7:57 am
St215 in St165
Airbox on right to turbo. The small alloy pipe is return line from blow off valve.
Exhaust downpipe before ceramic coating with separated waste gate pipe.
From underneath with downpipe now coated.
For more check my build, St215 motor + st205 gearbox into St165 JDM build
bmt
Postby pintoBC_3sgte » Sun Sep 30, 2012 5:44 pm
messy but finally got the engine/bay washed up this summer
pintoBC_3sgte
Postby bmt » Mon Oct 01, 2012 6:43 am
pintoBC_5sfte wrote:messy but finally got the engine/bay washed up this summer
Looks awesome! Any advice on how to clean an engine bay. Products, process used? Anybody?
bmt
Postby jonbonesjones » Wed Oct 03, 2012 12:54 pm
need a better picture and some cleanliness but heres a start
jonbonesjones
Postby pintoBC_3sgte » Thu Oct 04, 2012 11:31 pm
bmt wrote:Looks awesome! Any advice on how to clean an engine bay. Products, process used? Anybody?
I used a engine degreaser by detailers pride. Sprayed it on, let it soak in for a min. Scrubbed lightly with a coarse brush and rinsed. Fantastic product!!
I'll post a before pic later
pintoBC_3sgte
Postby warracer » Thu Oct 04, 2012 11:38 pm
Mine, really nothing special :|
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby DTE » Fri Oct 05, 2012 12:27 am
Here's mines, no go fast parts yet.
462
Devin
88 Celica All trac
DTE
Images: 5
Postby aus jd 2703 » Fri Oct 05, 2012 12:46 am
warracer wrote:Mine, really nothing special :|
how do you fint the turbosmart boost t?
seems good on my car just get different boost in all gears ie 5th= 17psi 1st =14psi
aus jd 2703
Postby warracer » Fri Oct 05, 2012 1:59 am
I like it a lot, easy to use and reliable , but for me its 11psi on all gear so... And it shouldn't be different boost pressure on each gear since its a mecanical turbo controller, ball/spring type to be exact, but I don't know could be different for you? :shrug:
____________
ST185H A-Spec:
warracer
Postby loudstealthGT-Four » Tue Oct 09, 2012 8:13 pm
Boost tee's are just a cheap form of boost control, its not unusual for boost pressure to fluctuate in different conditions, as they don't have a set PSI. It is simply a small ball and spring, which is not 100% reliable.
loudstealthGT-Four
Postby underscore » Tue Oct 09, 2012 8:35 pm
DTE wrote:Here's mines, no go fast parts yet.
462
Beautiful! That's so clean, I love what you're done with the silver.
Postby CSAlltrac » Thu Oct 25, 2012 4:03 am
The new and final look
Postby bmt » Thu Oct 25, 2012 8:34 am
^^^^ Nice. Tidy. Purposeful. 8)
Update; Featured on Speedhunters!! Congrats!!
http://www.speedhunters.com/2012/10/all-trac-fury/
bmt
