Post up your wheels.
Re: Post up your wheels.
Postby klue » Sat Nov 05, 2011 2:01 pm
Custom painted OZ chronos, 17x8 +35 235/40/17 hankook rcomp, stanced rear +40mm front +20mm.Does it grip? YES
Postby Sal » Sun Apr 08, 2012 10:42 pm
DR-31 17X9 All around with 7 offset in the rear and 28 in the front. Car is wrapped with 245/45/17 Tires.
'94 ST205 GT-FOUR WRC
13.3 @ 101MPH
Sal
Postby k.beaty » Sun Apr 08, 2012 11:02 pm
Looks awesome Sal! Best wheels I've seen on the car yet!!!
Follow me on Instagram @kbt666
k.beaty
Postby CSAlltrac » Sat Apr 21, 2012 5:37 pm
It looks good but I liked your RPF01s better :shrug:
Postby 5gencelica » Wed Jun 12, 2013 9:25 pm
225/45zr17 on konig 17x?7,5??? whit 25mm spacer on rear
706
705
5gencelica
Postby SkagTits165 » Fri Jun 14, 2013 1:31 pm
SkagTits165
Postby ALLensTRAC » Mon Apr 14, 2014 10:29 pm
Anyone with photoshop skills want to put Enkei NTO3+M wheels on Pats car for me? Pretty please?
These wheels:
Allen
ALLensTRAC
Postby celicast184 » Tue Apr 15, 2014 2:06 am
trying out these mesh wheels
I <3 MY ST214
celicast184
Postby celicast184 » Tue Apr 15, 2014 2:21 am
I <3 MY ST214
celicast184
Postby CMS-GT4 » Tue Apr 15, 2014 3:27 am
Here is a quick one, just cause I had PS open and was doing some stuff in it anyhow.
Had you not gone through the trouble of getting another car in the same angle I might not had. ;)
Postby ALLensTRAC » Tue Apr 15, 2014 11:37 am
CMS-GT4 wrote:Here is a quick one, just cause I had PS open and was doing some stuff in it anyhow.
Don't lie you know you did it cuz I said "pretty please" lol!!! Thank you for doing that. I think they look amazing!!! Now to figure out if I can pull the front fenders enough to fit the +27 without stretching tires ugh. I really want to run 285/30 with 14" brakes. We'll see I guess. Thanks again Josh!!!
Allen
ALLensTRAC
Postby CMS-GT4 » Tue Apr 15, 2014 2:24 pm
Running a tire that wide might require you to remove the fender liners. Gtfour77 ran the widest tires I know of on these. I think he was able to fit 275 40 17 by removing the liner. My 255 fills the wells quite a bit and I still slight graze a part of the liner which I need to adjust again.
Postby ALLensTRAC » Tue Apr 15, 2014 3:12 pm
CMS-GT4 wrote:Running a tire that wide might require you to remove the fender liners. Gtfour77 ran the widest tires I know of on these. I think he was able to fit 275 40 17 by removing the liner. My 255 fills the wells quite a bit and I still slight graze a part of the liner which I need to adjust again.
When it comes to the liners I plan to make custom ones using late model Lexus IS,ES,LS fabric liners as they conform much better than solid plastic ones. These won't mount to the lip of the fender though as they will only cover the door hinge area and then enough of a channel under the fender to cover the new tucked harnesses. I am worried about the wheel being out too far to cover it safely with the fender. My +35 was right at the lip although I had almost zero camber dialed in.
Hey here's a thought I had, could I slot the fender mounting holes slightly to pull the entire assembly out by 1mm maybe? This would require metal work at the seam near the hood for alignment but it would increase clearance1mm before the pulling begins. Didn't Martin cut the fender edge to fit the 275 or was that the 315? There was also that white 185 that Hideki posted with the fenders and hood spaced. It was running 265/35 but that is way too tall for me. I really like the height of the 285/30 it's just the width that's going to cause problems.
Allen
ALLensTRAC
Postby CMS-GT4 » Tue Apr 15, 2014 3:16 pm
I am curious about this fender fabric. Can you buy just the material and cut it? I had seen race cars with cf liners. I thought about making something out of fiberglass. I knew an autoxer who used quick roof to make his. Its essentially strong plastic with adhesive on one side.
Postby ALLensTRAC » Tue Apr 15, 2014 3:27 pm
I'm not entirely sure if it's available in bulk. I have to replace one on a customers ES this afternoon so I will take pictures and post them so you can see it. I think using a larger cars liner trimmed and then heated to fit would be best. This would discourage low spots and sagging. The LS460 would be best but I don't know how much they cost.
Allen
ALLensTRAC
