I'm now in the full 3" club...
Postby Stubble » Sat Apr 28, 2007 2:04 am
3" exhaust that is.
Aussie DP and MP have been on for a year; I finally got around to putting on the HKS Silent Hi-power. (p/n 31019-AT009) C$750 from Speed Factor in Winnipeg.
Toyota wanted $30 for a new rubber insert. Mine went missing some time ago, so I have this ghetto solution of rolled up rubber.
First impressions - Fitment is excellent. The ghetto mount near the resonator actually helped with side-to-side positioning, which helped with clearance over the rear subframe. No problem with clearance over the rear crossmember.
The sound is great, especially at idle. I'm not sold on the look though. Much too ricey for my tastes.
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby gpmarzan » Sat Apr 28, 2007 11:11 am
Looks good. Im also not into the look of my motoria muffler, which almost looks like your canister. I liked how my old magnaflow muffler looked, with the oval shape and 4" short tip. Looked very clean. I think I definately added some rice points for how the motoria looks on my car.
Patrick M.
st165
gpmarzan
Postby Autobot » Fri May 04, 2007 10:36 pm
Looks good. Haven't been to Speed Factor since I bought my ST185, I wonder what else parts they can get a hold of for our cars.
Autobot
Postby sims » Sat May 05, 2007 10:37 pm
I just get my tires through them, Matt's a good guy.
http://www.speedfactorracing.com
their primarly a Honda shop, but so is anything local :cry:
No whiteline or TWM, I asked list time I was their.
they qouted me about 1850Cnd for a set of Tein SS for our cars.
sims
Postby Stubble » Sun May 06, 2007 8:47 pm
Speedfactor can get everything that jrponline.com can get, since they distribute for them. I've only bought a couple HKS parts there, but the experience was good...with the exception of HKS pricing. "You want how much for a head gasket?"
Brady Ryall
1990 ST185 Black
1999 Miata
Stubble
Postby Gary ST165 » Mon May 07, 2007 1:35 pm
full 3" system: >>> do you suffer with boost creep?
ST165 turbo 4WD
Gary ST165
Postby Autobot » Mon May 07, 2007 9:48 pm
I've dealt with Matt at Speed Factor before, nice guy. Hmmmm, 1850 for Teins....
Autobot
Re: I'm now in the full 3" club...
Postby ishmael.7 » Wed Feb 12, 2014 7:29 pm
Hello. I am planning on buying this exhaust. It says japan spec even though mine is USDM will it still fit? I am guessing yes but I just wanna make sure
Update. I just ordered it, I hope it fits.
ishmael.7
Postby CSAlltrac » Thu Feb 13, 2014 3:44 am
It's beautiful! Nice and shiny. Wish mine was like that still, my HKS can is scraped from the previous owner. Someday I want to replace just that.
ishmael.7 wrote:Hello. I am planning on buying this exhaust. It says japan spec even though mine is USDM will it still fit? I am guessing yes but I just wanna make sure
It will fit fine, you will love it.
Postby ishmael.7 » Thu Feb 13, 2014 5:31 am
Thank You. Yes mine is all rusty and looks like it is about to fall off.
ishmael.7
Re:
Postby smog7 » Thu Feb 13, 2014 5:50 am
Gary ST165 wrote:full 3" system: >>> do you suffer with boost creep?
Why would he suffer from boost creep?
-omar
rally tarmac 1990 st185
smog7
Postby warracer » Sat Mar 01, 2014 2:52 am
little to no restriction in the exhaust system can cause boost creep, since the turbo is acheiving boost easily with the impeller. Its almost running freely with little to no restriction, the wastegate can't keep up and thus, boost creep.
____________
ST185H A-Spec:
-IHI VF28 -BC Racing coilover
-Yonaka FMIC -Swift Spring
warracer
Postby Meenya » Sat Mar 01, 2014 2:56 am
It also appears that cheap ebay DPs don't allow the wastegate to open completely and therefore making boost creep even more likely to occur.
Mike
93 Turbo 4WD
91 GTFour RC
07 R6
Meenya
Images: 19
Postby Chuck.hudson » Sat Mar 01, 2014 3:27 pm
Yea I ran into that problem myself. All you have to do is open up the holes where the dp bolts to the turbo and it will give you enough play to adjust the dp so the wastegate doesn't hit it. Now will the dp crack cause its cheaply made? Time will tell.
Chuck.hudson
