My Celica st185
My Celica st185
Postby sss7556 » Fri Dec 03, 2004 8:58 am
Hello, all!
I am glad, that forum was opened, again!
Look at
http://www.alltrac.net/phpBB2/album_per ... ser_id=753
some pics of my Celica.
My pleasure....
Alex
sss7556
Postby pog0 » Fri Dec 03, 2004 9:16 am
What motor is that? Looks like it is a caldina motor with the heatshield, got the side feed intake manifold, and is that DFI?
Kevin Hall
92 Gray ST185 - Sold
01 GGP IS300 - Sold
06 GG Evo IX MR
San Diego
pog0
Postby sss7556 » Fri Dec 03, 2004 9:35 am
thank you for attention!
of course, it's 3gte IV generation. 1999 from Toyota Caldina gtt, 2.0l 260hp in stock,
turbo st26 IV stage 26/35r, 44 lbs/min up to 450hp
manifld, stock from st205 Celica gt4
SMC 1.92 Autronic, ERL Aquamist 2s system
.. are some mods for you,
many thanks
Alex
sss7556
Postby Zeus » Fri Dec 03, 2004 2:18 pm
wow very nice...
is the ignition stock?
very cool man
Blake Brown
Zeus
Postby AWDios » Fri Dec 03, 2004 3:46 pm
:shock:
Why haven't we seen you around before? To the best of my knowledge you're the only one to do a 4th gen swap. There have been quite I few interested people so I hope you can bring your knowledge to the table here.
Awesome.
www.pstoc.org
Formerly known as GT-Four195
AWDios
Postby turbo4wd » Fri Dec 03, 2004 4:21 pm
AWDios wrote::shock:
Awesome.
Theres a guy living here in So Cali who has done a Caldina swap into a st185.. the infamous $$$$$ swap done by Toysport.. I believe the story of it is somewhat told on their website..
Dan
Undercover Moderator
turbo4wd
nice....
Postby speedlabracer » Fri Dec 03, 2004 9:36 pm
hey what kind of engine management do you have?? Very nice....... Oh who won in that picture, between you and the bike?? Later
3sgte POWERED midnight blue 1990 CELICA ST......the shark...SOLD!!!!
93 White MR2.....my new baby
White 1990 CELICA ALLTRAC....sold to James
speedlabracer
many thanks
Postby sss7556 » Sat Dec 04, 2004 7:49 am
Dear, friends!
Many thanks for the replyes!
_______________________
about car
ignition system are stock for this engine
I had nic - sss7556 at old forum, but I can not sent some pics about Celica
I have SMC 1.92 Autronic for engine management with some mods for dwell board for ignition system.
and gas analyzer Autronic B with UEGO O2 sensor for accurate tune. Celica was winner, bike was not so fast :wink:
________________________
Thank you very much!
Alex
sss7556
changed some pics
Postby sss7556 » Sat Dec 04, 2004 10:04 am
Hello
I'v changed some pic on my gallery
http://alltrac.net/phpBB2/album_persona ... ser_id=753
Alex
sss7556
Postby b00staholic » Sat Dec 04, 2004 6:37 pm
Look at his post above, he said he has the SMC 1.92 Autronic as engine management.
Vincent
'90 ST185
b00staholic
Postby 2of81 » Sun Dec 05, 2004 7:24 am
450HP CT26? I'll believe it when I see the dyno #'s. BTW nic looking setup!
Justin
1972 Corolla TE27
2of81
Postby Puffy » Sun Dec 05, 2004 9:18 am
Nice motor to swap into a 185. The wiring looks a bit rough but as long as it all works I guess.
The radiator looks to be different and what sort of suspension are you running ?
Cheers
Puffy
Postby sss7556 » Mon Dec 06, 2004 1:16 am
450hp for ct26, of course, I am not sure. May be, I am wrong (44lbs, I know). It's upgrade from ct26 MA70 Supra turbo. I'll change to gt35r with a good design manifold on the next year.
About, wiring, so sorry. It's really in the first step.
Suspension are Tein at all set.
Clutch system - Cusco single clutch set to 12550n/f
Alex
sss7556
Postby sss7556 » Mon Dec 06, 2004 2:47 am
about ignition system:
stock engine has 2 inductive sensors on crank and camshaft.
I have changed its on hall sensors and made crank disc with 2 tooths (as a 60-2 Motronic ignition. system). Dwell board has mod for max power ignition coils.
About engine:
stock has CR 9.0:1, 260hp for ct20b with specific manifold.
My engine has CR 8.9:1, JE 86.5mm pistons set, 1.5mm gasket, 264 HKS camshafts with adj. cam gears, titanium retainers and plates, very strong springs, polished and drilled int., exh. ports for head and some works...
I have some experiment for some camgears, such as: stock from st185 (4,285 main .diff.ratio), 4.83 (Toyota Rav4) was very power on low RPM, but not enough for max boost and 4.11 (form Toyota Carina ED 4wd st205) very good for turbocharged engine and a good max boost.
I think 3.93 will be very good for max power.
Thank you very much for the great attention
Alex
sss7556
a new pics
Postby sss7556 » Wed Dec 08, 2004 9:13 am
Hello, all
Look a new pics, please.
Alex
sss7556
