Sleeper's red ST165 pics March 15th 2010 UPDATE!
Re: sleeper's red ST165 pics MORE PICS!
Postby sleeper » Mon Mar 15, 2010 7:41 am
not alot of updates here, but here is a few pictures of how the engine looked last season.
The car is in the garage this winter, and will hopefully be done in about 3-4 weeks.
Some of the changes i have done is:
New ignition system ( autronic 500r cdi with 4x gsx-r 1000 cop)
poly bushings in the diff cradle, welded rear diff.
other plans i have is: st205 rear brakes, tein coilovers, 3.5" exhaust, larger cams.
sleeper
Re: Sleeper's red ST165 pics March 15th 2010 UPDATE!
Postby Rawbz » Mon Mar 15, 2010 9:10 pm
wow looks great.... i gotta get my conquest out of the garage so i can put my 165 in and start putting lots of money into it
Rawbz
Postby klue » Mon Mar 15, 2010 9:21 pm
a+ for big turbo.
Postby sleeper » Mon Mar 15, 2010 9:41 pm
klue wrote:a+ for big turbo.
Guess you now see why i need a larger exhaust :lol:
sleeper
Postby Rawbz » Tue Mar 16, 2010 7:02 am
a few questions if you dont mind
What generation engine are you running along with harness... (i have a 185 with WTA IC and i believe the 165 ecu.. not sure)
What the compression
Where do i get the Distributor insert to run a coil ignition system
what intake manifold and TB is that... and where can i get one
what componants are you using for the fuel system
thanks
Rawbz
Postby sleeper » Tue Mar 16, 2010 7:50 am
Rawbz wrote:a few questions if you dont mind
thanks
The engine is a 2002 5sfe block ( from 2.2 liter camry) and a 2 gen 3sgte head.
the harnes is a st165 one, but have been modified to use autronic ems.
Compression is 9:1
I`m only using the distributer as a trigger ( cyl and ref), the distrubution of spark is taken care of by the autronic smc\ autronic 500r cdi box
That is a rmr racing intake manifold, do a google search and you will find it, TB is a bbk mustang 76mm one.
As Fuel sysem i`m using a custom pickup in stock tank, SX fuel pump \filters\FPR, custom fuel lines, speed source fuel rail, 1600cc injectors, fuel pump runs at 16.5V at boost ( controlled by a kenne bell thingy.. )
sleeper
Postby 801Alltrac » Mon Jun 14, 2010 5:09 pm
very nice man keepn my dream alive, any est. on whp?
801Alltrac
Images: 13
Postby sleeper » Wed Jun 16, 2010 8:36 am
Thanks.
The car have never been to any dyno, but from trap speed i would guess a little over 600awhp..
sleeper
Postby 801Alltrac » Wed Jun 16, 2010 12:38 pm
What trans you using, and on that intake did you have to smash the strut bar to get it to fit
801Alltrac
Images: 13
Postby sleeper » Wed Jun 16, 2010 2:51 pm
801Alltrac wrote:What trans you using, and on that intake did you have to smash the strut bar to get it to fit
Stock st205 trans.
Yes i had to smash it some...not much but some..
sleeper
Postby sleeper » Thu Jun 17, 2010 9:05 am
Video of a 402m test run i did a week ago...
http://www.youtube.com/watch?v=Z-h_OiMhbP4
sleeper
Postby LegacyofDan » Thu Jun 17, 2010 11:24 am
Nice man!
Postby Mafix » Thu Jun 17, 2010 4:40 pm
damn. looks like you might need a bit more tire!
Postby sleeper » Thu Jun 17, 2010 6:25 pm
Mafix wrote:damn. looks like you might need a bit more tire!
No shit.. :evil:
This was on a old airstrip with concrete and no trackbite.. so traction was a big problem for all that was there.. ( also noticed that the stock st205 center diff is having trubble moving enough power to the rear wheels. the front tire was spinning alot more than the rear.. )
sleeper
Postby 801Alltrac » Thu Jun 17, 2010 6:52 pm
:notworthy: that was sick and :crazy:
801Alltrac
Images: 13
