Marlon order your valve cover gaskets from the dealer, I want to say they're only like 20 bucks or so. There are two of them so make sure you get both. Then get a tube of Toyota's high temp silicone, you need to use a little bit on certain parts of the valvecover when your installing it. I would also consider buying the replacement valve cover bolts from twosrus.com or something similar. The stock hardware is junk. After that its pretty straight forward, take off the IC, remove the plug wires, take off the throttle body & the support under it. Then its just about removing the stock bolts, once theyre off take off the cover and clean up the surface that the valve cover mounts to. Then its all about installing the new one. If you have the BGB look it up, tells you where to put the silicone and what the torque specs are. If you dont have a BGB let me know and I'll see if I can scan that page for you.
