Show off that cage and stiffening mods
Re: Show off that cage and stiffening mods
Postby Mafix » Thu Jul 12, 2012 3:39 pm
the frame connectors are 3"x1" thick wall steel. not the cage. my cage is an autopower.
Postby celigts » Thu Jul 12, 2012 4:09 pm
Oh! That's thick woo
3SGTE project motor very slow
celigts
Postby celigts » Mon Aug 06, 2012 1:16 am
K so mafix you really have 1" thick by 3" wide for along the rockers? And steel right. Cuz I'm gonna order some from work or if we have I'll be grabbing some to place them on the car. Please elaborate for me what you did if it's as easy as welding them on.
Also have a question for the cages. I have found a tig welder to do work for me and am needing some insight on wether to go for chromoly aluminum and have the cage bolted in or have it in a steel and welded in.
celigts
Postby Insanity-74 » Mon Aug 06, 2012 12:04 pm
I dont quite know what chromoly aluminium is? but aluminium cages are now banned by most if not all motorsport regulating bodies, but I can see the appeal being light, I nearly went down that route myself......there are two "usual" choices for steel cages, CDS tubing which is Cold drawn seamless mild steel tube, of the lighter but more expensive T45 chromoly tubing, still steel but stronger and lighter.....it welds very nicely too.
Insanity-74
Postby celigts » Mon Aug 06, 2012 4:16 pm
Oh well maybe that's the chromoly I was thinking of. I'll pass the steels to my guy and so excited to follow up and have something started.
Any good reference sites to see for our cars that have been done.
celigts
Postby Insanity-74 » Mon Aug 06, 2012 6:48 pm
I have loads of st205 pictures, but not many 185 pictures...I can try and dig out some 185 TTE cage shots if you like, but it depends on how much of a cage you are going to fit, a full blown group N cage or a cheap n cheerful 6 point bolt in style cage?
Insanity-74
Postby Mafix » Mon Aug 06, 2012 7:15 pm
T45 chromoly tubing
this.
the rear i had to add a small step.
and the cage pre-install
Postby celigts » Mon Aug 06, 2012 9:32 pm
I'd like to do what I can and have it as professional and not cheap out. A cage will give me more confidence and feel better knowing it will handle what I'll throw at the car.
I'll be starting with autocross so if 4 point will be sufficient then cool but if my builder would rather do it up to the 6 point then be my guest I'll make it happen if he wants to help and bring it the extra mile.
He has never done a cage and is just a fabrication tig welder so he has the skill but will need to do himself some research. Anything I should help him out with? Steps I should let him know of if he doesn't find out.
Should I remove the headliner when he does this?
Mafix that step was to keep it level along the rocker right? Do you have the full job in your project thread?
celigts
Postby Mafix » Mon Aug 06, 2012 10:00 pm
yes but not on this forum. on st162.net.
at no point does your car call for a roll cage in autox. just an fyi. weight vs tire size vs suspension. the only 3 things that matter in autox...it seems.
Postby Insanity-74 » Tue Aug 07, 2012 4:43 am
celigts wrote:I'd like to do what I can and have it as professional and not cheap out. A cage will give me more confidence and feel better knowing it will handle what I'll throw at the car.
You can pretty much do what you want as long as you prepare it correctly, the only sequence I would suggest is do not weld the cage to the car until you have welded the top of the cage together, it's impossible to get a welder to the top of the cage with it in place unless you cut holes in the roof.
You will have to remove the headliner and all the interior plastics near to where you want to fit a cage, the heat from the welder will set it on fire. If you follow the "rules" of fitting a cage to the letter, then the cage should be as close to the outer shell as possible so no room for a headliner, but as with anything you can make it as you wish and leave a gap, the cage will still do its job, but will allow the car to crush a little in the event of a crash. Not ideal but not a catastrophe.
I am just fitting a rear cage, the main hoop from the b pilar backwards, but full on rally style, a four point cage would be fine, but I would at least put the diagonals in for strength, so five tubes in total plus at least 3mm steel for the mounting points.
I have rushed this a bit as I am just off to work, but basically, do the minimum that you want to start off with, you can always add more later if you want, it's hard to take stuff away.
Also choose the wall thickness carefully, too thin and it won't do it's job and it won't bend right, 2.7 mm is the current recommended thickness for roll cage tubing.
Insanity-74
