My 1990 Celica GT Four (RC Conversion)
Re: My 1990 Celica GT Four (RC Conversion)
Postby Redswan » Tue May 26, 2015 12:57 am
However, in the midst of this chaotic move and getting ready to put the car and trucks in storage for a year. I managed to finish the ST205 ECU swap. I was having some trouble with my wiring so I removed the 540cc injectors and have to put them back in, but everything works.
***************YOUTUBE VIDEO*****************
https://www.youtube.com/watch?v=90XsxD5iPww
EDIT:
I got the injectors in there it took less than an hour. I already bored out the fuel rail to 8mm (from 6mm) a few weeks ago. so they just dropped in. It idles much lower and smoother. I wish i hadn't unplugged and packed my boost controller accidentally :( this would be fun to play with.
-Mike
2005 4Runner V6 4x4 URD S/C'ed (Mojave)
1990 Celica GT4 RC (Revanche)
1990 Celica GT4 RC Conv-Sold 2008 (Redswan)
Redswan
Postby Redswan » Tue May 26, 2015 6:56 pm
nickfootball wrote:
Redswan wrote:Also for this RC Badge remake...I need to know how much demand there is for them before I make a run at it.
Hi Mike,
I'd take 2 RC badges if you do manage to make them. I also think you would get a good demand for them. I can ask on the gt4oc site to find numbers interested?
Well done on the purchase of the RC number plaque, what a find! I have been looking a few years too but not as long as 15 years so you well deserve it :) can I ask how much it cost? I have seen one previously before but that was going for approx $1000!
I will finally take one of your replica plaques if you still have them, I have your details via IM.
Your project is looking brilliant and I look forward to more updates on it.
Nick
I found them. If you still want them please let me know. I am leaving the country soon.
-Mike
Redswan
Postby Redswan » Tue May 26, 2015 6:57 pm
underscore wrote:I'd take a few as well, probably a good idea to have some spares if they're discontinued.
I found them. Please pm me. I'm out of here soon and would like them sold before I go.
-Mike
Redswan
Postby Redswan » Wed Jun 03, 2015 5:07 am
So an update and hopefully the last for a while. The car is running and driving. Honestly it it is faster than the stock USDM ECU that was in there.
Issue:
I have a Code 52 that I cannot seem to get rid of on either ECU. It comes on after the car has cycled through the cold start, if you rev it past 3k RPM the CEL comes on.
Corrective actions:
I changed the wiring to a shielded coax cable with a solid core (75 Ohms) NOTHING ......
I replaced the sensor with a new OEM one NOTHING...
Its still throwing the same code 52 on both ECUs
The only other thing I can think of is the fuel injectors the car was running great on the 440s
any ideas on knock sensor woes?
-Mike
Redswan
Postby underscore » Wed Jun 03, 2015 2:29 pm
How are your motor mounts? A friend of mine went through probably 7 knock sensors on his MR2 before he found out one of the mounts was trashed and causing knock to be detected.
Postby Redswan » Mon Jun 29, 2015 5:29 pm
So... it was the ST205 Igniter. I swapped back in the ST185 RC one and it quit tripping the knock sensor. The boost went back up and the fuel cut sure works. I put it in long term storage today and said adios! So I guess I will start saving up for my next round of mods.
-Mike
Redswan
Postby Corey » Mon Jun 29, 2015 9:12 pm
Awesome you solved the issue. I wonder if maybe it was a bad ignitor? I found that with my car, the rev limit was set too low with the 185 ignitor.
Corey
Images: 50
Postby Redswan » Tue Jun 30, 2015 2:40 am
Thanks man! its fitting that I figured it out on the day i put it in storage for a year. SIGH oh well at least it won't be bugging me anymore.
For the Rev limiter. The ST205 one is revving to almost 7K, but it kicks in the knock at 3K. I swapped them, and now I have to tune my boost controller to avoid the new fuel cut.
-Mike
Redswan
Postby Redswan » Tue Jul 07, 2015 10:09 pm
So, I finally found a deal on a ST205 Power FC, too bad I won't be putting it on anytime soon.
I did some more research. I used to have an OS Giken twin plate for my old GT4, but now days they actually make a street compatible sprung twin plate. I'm trying to source one of these. We will see how it goes.
...Let the parts stock piling begin.
-Mike
Redswan
Postby Redswan » Sat Jul 11, 2015 2:25 am
I went ahead and placed an order tonight for the OS Giken STR clutch from greenline.jp. I've never done business with them, but they were quick to respond to my questions so far.
-Mike
Redswan
Postby Corey » Sat Jul 11, 2015 4:12 am
If it comes with flywheel bolts, I would check the height of the bolt head compared to OEM. I once owned an ORC 409 single plate clutch which might be similar to this one. It came with bolts with a low profile head. I thought this was a poor design, and decided to use the OEM flywheel bolts. Little did I know, the low profile bolts were so for a reason. After 60k km, as the disk wore down, it moved closer and closer to the crank - and the bolts. Eventually, the disk started to grind against the flywheel bolts.
The low profile bolts were designed to prevent this.
Corey
Images: 50
Postby Redswan » Sun Jul 12, 2015 11:10 am
Thanks again Corey. I will definitely keep that in mind.
-Mike
Redswan
Postby Redswan » Wed Jul 15, 2015 3:15 pm
I found a pair of sparco CS shoes in my search to find the end of the internet.
-Mike
Redswan
Postby Redswan » Sun Oct 11, 2015 12:59 pm
Not home but still out in search of adventure
[youtube]n3PlmGXBwP0[/youtube]
https://www.youtube.com/watch?v=n3PlmGXBwP0
-Mike
Redswan
Postby Redswan » Sat Jan 16, 2016 6:43 pm
So I have been compiling parts and CS goodies the past 6 months or so.
1. OS Giken STR clutch
2. Apex'i Power FC (ST205) already running the stock ST205
3. Greddy TD06 Kit (thanks Frantz)
I acquired some rare Carlos Sainz Goodies too
1. Sparco 1992 Carlos Sainz Helmet (working replica)
2. Sparco Carlos Sainz shift knob
3. Sparco Carlos Sainz racing jacket
4. Sparco Carlos Sainz racing shoes
Hopefully I can get home in the next 6 months to get all this put together :D
-Mike
Redswan
