My new st165 w/Gen 4 swap
Re: My new st165 w/Gen 4 swap
Postby klue » Tue Dec 01, 2015 1:41 am
eric thompson wrote:I understand proper break in, being a tech since a teenager and a Svc manager for 8+ years now, hence why I have been shifting nice and smooth and haven't gone above 4500 rpm yet. But I never thought boost @3k rpm while already in gear would be enough for the clutch to start slipping.
Your response sounds a bit defensive, im not suggesting you dont know what your doing. Just suggesting that 250ftlbs will cause a clutch to slip and glaze.
Postby eric thompson » Tue Dec 01, 2015 1:52 am
Sorry man. I'm just extremely frustrated as I'm sure you can understand.
ST165-PARTS-RED
NEED ONE MORE FOR STREET:)
https://www.youtube.com/watch?v=w-RCuV_Hmqk (ITS miata 6spd,4.78 rear, shitloads of fun!! multiple wins and track records in 2014)
eric thompson
Images: 6
Postby CSAlltrac » Tue Dec 01, 2015 1:36 pm
I would continue to baby it, you cant really count the long journey home as break in mileage either. Having the clutch engaged for a long period of time does not do anything for break in. Stop and go driving is whats needed for a minimum of 500 miles, I would do 600-1000. Once you have that kind of mileage of stop and go, ensure everything is adjusted and bled, then try your boosted runs. Everything should be good from there, if it is still slipping after all of that contact Prime. Justin and all the guys over there are very stand up and Im sure they would be more than willing to help you out.
Postby klue » Tue Dec 01, 2015 8:29 pm
eric thompson wrote:Sorry man. I'm just extremely frustrated as I'm sure you can understand.
I know man, no hard feelings.
Like cs is saying ride it out for a bit take it easy on it. it might bed in some more. Im guessing its organic material?
Postby eric thompson » Wed Dec 02, 2015 1:44 pm
Its whatever they sell on their site... South Bend stg2 daily.
I've been advised that since the Clutch Master Cyl is original I should replace and bleed system.... Pretty sure we all know that will have ZERO effect on slipping.
Guess I'm now using my suspension budget for the clutch. FML!
ST165-PARTS-RED
eric thompson
Images: 6
Postby MARLON1211 » Wed Dec 02, 2015 1:50 pm
eric thompson wrote:Today is day 1 with my new st165 w/ a Gen 4 swap courtesy of Prime Performance. ST205 trans, 15x8 +20 225/50 tires. It needs some TLC but the motor feels great so far.
Cool man congrats. Bryan and his team are the best in NJ.
I also live in NJ maybe we can meet someday and check out the car.
SO BE IT
MARLON1211
Postby klue » Wed Dec 02, 2015 7:23 pm
eric thompson wrote:Its whatever they sell on their site... South Bend stg2 daily.
Yes your right, slipping is all in the mechanics of the PP.
If you cant get any help with the clutch let me know, I will get you a good rate
Postby underscore » Thu Dec 03, 2015 3:46 pm
Stupid question but what clutch slave rod is in there? I thought our cars could have clutch engagement issues if the length isn't right.
Postby eric thompson » Thu Dec 10, 2015 11:51 am
underscore wrote:Stupid question but what clutch slave rod is in there? I thought our cars could have clutch engagement issues if the length isn't right.
OEM as far as I can tell. I will be replacing the slave as well and installing the extended rod
ST165-PARTS-RED
eric thompson
Images: 6
Postby CSAlltrac » Thu Dec 10, 2015 1:27 pm
Have you contacted Prime at all?
Postby klue » Thu Dec 10, 2015 8:00 pm
the extended rods dont do anyhting except change the postion in the slave which is being used
Postby eric thompson » Thu Dec 10, 2015 8:06 pm
klue wrote:the extended rods dont do anyhting except change the postion in the slave which is being used
I know. Just playing it safe once repaired.
ST165-PARTS-RED
eric thompson
Images: 6
Postby eric thompson » Thu Dec 10, 2015 8:08 pm
CSAlltrac wrote:Have you contacted Prime at all?
I have but not very eager to help....
ST165-PARTS-RED
eric thompson
Images: 6
Postby CSAlltrac » Thu Dec 10, 2015 8:25 pm
I would pressure them into helping you, in a professional manner I mean. Ask if they can provide parts or cover at least half. I would think that is fair. That's a surprise that they aren't wanting to help much. They have always been very stand up when I have dealt with them. :shrug:
Postby eric thompson » Thu Dec 10, 2015 8:34 pm
I had no problems with Justin at all but he was definitely vague on some details of the swap.... More should's and probably's than I would give my customers... But I overlooked it since I wanted the car so much.
ST165-PARTS-RED
eric thompson
Images: 6
Users browsing this forum: Google [Bot] and 6 guests
