Spring cleaning sale!
Postby klue » Tue Apr 15, 2008 10:34 pm
Ive got alot of extra parts if anyone needs anything.
stuff like
st185 and st165 iginiton wires, rotors, cap, plugs
st185 complete front suspension with hubs and swaybar
st185 2pot calipers
st165 brake rotors, pads
st165 intake manifold, complete intercooler, truck plastics,fuelrail, injectors,
st165 turbo, manifold
st185 turbo, downpipe
lots of RHD interior parts too
i have more suff just pm me and ill tell u if i have it
Postby incubus_boader » Wed Apr 16, 2008 11:25 pm
is this from a half cut? I need the center vent assembly, a passenger sun visor, and prolly a few other things
incubus_boader
Postby klue » Thu Apr 17, 2008 12:33 am
yes from a half cut, JDM 91 grey interor.
I have the center stack, but no visors, the cut was made where the A pillar joins the roof
Postby incubus_boader » Thu Apr 17, 2008 1:16 am
ok sweet after finals are over (april22) i'll contact you so we can meet up
incubus_boader
Postby klue » Thu Apr 17, 2008 1:25 pm
ok sounds good!
Postby exST165 » Tue Apr 22, 2008 2:28 am
If you are still looking for a passenger side sun visor for a ST-165 in grey let me know. Or any interior pieces for that matter. Probably not worth too much but every penny goes back into the budget!
Thomas
exST165
Postby klue » Tue Apr 22, 2008 3:27 am
ACTUALLY, im looking for the door lock bezel clips, the center peices(one for radio, other shifter/armrest) and the plastic that goes over the steering colum. driverside Apillar, and a sunroof shell,
Postby hacker_720 » Tue Apr 22, 2008 1:23 pm
"st185 complete front suspension with hubs and swaybar "
how much you want just for the front hubs? My wheel bearings are shot, so I figured getting new hubs is probably easier they trying to find wheel bearings.
BOTTLE ARE FOR BABIES...REAL MEN GET BLOWN
1990 ST185 2.2Lt
hacker_720
Postby exST165 » Tue Apr 22, 2008 11:39 pm
klue wrote:ACTUALLY, im looking for the door lock bezel clips, the center peices(one for radio, other shifter/armrest) and the plastic that goes over the steering colum. driverside Apillar, and a sunroof shell,
I still need the plastic over the steering column and the center console for the radio (not to mention they are kinda hacked up), but the shifter/arm rest, A pillars and almost everything to do with the sunroof (head liner, inside of sunroof headliner, sunroof, etc) is for sale. I think that I have the dook lock clips and would be willing to sell them for the right price.
Shoot me a PM with what you think they are worth and we can try to arrange a time/place to hook up.
Thomas
exST165
update
Postby klue » Sat Apr 26, 2008 4:28 pm
st165:
JDM ECU
complete intercooler system
intercooler coupler
TB complet + brakets
oil pressure sensor
cruise complete with calbes
rebuilt turbo
front and rear seats blue leather
rear seat back interor parts blue
calipers and brackets
ebc green pads
3.5 inch alpine speakers, or 3.5 inch stockers
6.5 inch alpine rear fitted in boxes(fits in stock location no mods needed) come with tweeters and xovers adjustable
stock springs
brake booster
exmanifold
ac compressor
intake manifold
complete Power steer system
rad fans
AC fan
AC system complete
intercooler complete
cam gears stock
cam gear metal back plate
EGR
valve cover
st185
sway bar bushings front + sway bar
water pump 60kms
oil pump 60kms
wiring harness
turbo pressure sensor
coil
both resistor packs
wheel plastic liners
strut bar
frnt rebar
full RHD interior
front suspension complete W hubs
rad hoses
coolant overflow
ex manifold
JDM ECU
starter
3Xalternator covers
st165 fuel rail and injectors
st165 intercooler hard lines
st165 dizzy, antenna mast, rear seat belts, A/C idle up
transmission side engine mount(no rubber)
st185 radator lower hose, radiator top brackets, intercooler, intake manifold brace's, intake hose, left right xmember, windsheild cowl, A/C idle up
st185 dipstick, shifter U retainers, retractor control boxx2, injector resistor pack, tilt steering control box
Left and right headlight motors
Lots of hoses' Brackets, and crap!
Postby klue » Sun May 11, 2008 6:29 pm
bump
Postby timmey » Tue May 20, 2008 7:37 pm
JDM ECU for an ST185? Still around? Any more details?
Cheers!
timmey
Postby klue » Wed May 21, 2008 10:53 pm
yep JDM ecu ready for pick up. PM please
Postby klue » Thu May 22, 2008 12:26 am
Postby Rick89GTS » Thu May 22, 2008 1:39 am
Klue,
Got this hose for the ST165 in good shape?
Rick89GTS
Return to Canada
