Ontario emission test
Postby crazy_russian » Sun Jan 18, 2009 7:56 pm
Here is my test report for a stock car with all cats in place.
http://besm8.kgbconsulting.ca/~gregk/alltrac/celica_emissions.jpg
How does this compare to yours?
What are the HC (hydrocarbon) readings like without the front cat?
88 ST165
crazy_russian
Postby vash169 » Mon Jan 19, 2009 2:44 am
On a 3 inch system with no primary cat, and a brand shiny new 3' high-flow cat in the secondary position, my HC at 2500 and at idle was about 10, and the CO% was around 0 to 0.05 if I recall. I couldn't believe how low the number was. With no cats I was failing at idle only, the HC at idle was about 210-240. No amount of cheating could lower that, so I had to go the legit route with a cat.
vash169
Postby crazy_russian » Mon Jan 19, 2009 4:21 am
That's way better than mine. I wonder if that's because of the new cat. Is your O2 sensor relatively new too?
I wonder if it's possible to improve idle HC a little by making it idle faster. Your numbers and mine both show that HC at 2500 is better than at 1000. I think the machine accepts anything under 1500rpm as an acceptable idle range, so raising idle to say 1400 might improve HC. What do you think?
Oh and wish me luck on the emissions test tomorrow. Hope she passes.
88 ST165
crazy_russian
Postby ___Scott___ » Mon Jan 19, 2009 4:31 am
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby vash169 » Mon Jan 19, 2009 6:47 pm
Yeah it was brand new when I got the test. Got it welded in, went for a rip on the highway, then went straight to the tester. I think I did have a new O2 sensor at the time too, it was a cheapo universal one that I got because I suspected mine was fouled by seafoam.
vash169
Postby crazy_russian » Sat Jan 31, 2009 8:56 pm
IT PASSED! Having no front cat I did not take any chances and kept the car running at 2000rpm for the 10minute I had to wait. Result HC: 54 idle, 40 at 2500rpm. Note that it's almost half the HC than two years ago with both cats. Keeping the cat hot on cold winter days makes a LOT of difference.
88 ST165
crazy_russian
Return to Canada
