91 GT4 Brake Pads
91 GT4 Brake Pads
Postby canadiazn » Fri Oct 08, 2010 6:47 am
Hi,
Having no technical knowledge about my car I didn't realize that the 91 JDM Celica GT4 brake pads do not match the North American Alltrac... I need to source front (and eventually rear) brake pads for the car. Does anyone know where I should be looking? I read that the 90/91 is different than the 92/93? Are there any suppliers in the Vancouver area?
Thanks in advance,
Zillion
canadiazn
Re: 91 GT4 Brake Pads
Postby klue » Fri Oct 08, 2010 4:28 pm
The early st185 jdm uses the same pads as the st165 1988-1989 celica alltrac. The back pads are the same as the USDM st185.
Postby canadiazn » Fri Oct 08, 2010 8:45 pm
Thanks for the quick reply. My mechanic says the 88 alltrac pads do not match. Maybe I have the later generation brakes?
canadiazn
Postby canadiazn » Sat Oct 09, 2010 5:46 am
Wait, should the later version GT4 have the same pads as the 90-93 canadian alltrac? Maybe my mechanic only looked on the other models like gts and gt... :bangshead:
Sorry for ignorance.
canadiazn
Postby klue » Sat Oct 09, 2010 5:49 am
You need to use an alltrac pad from the st165. They share the same brakes
Postby canadiazn » Mon Oct 11, 2010 9:30 pm
I do have an early model car, but my mechanic says the pad on my car looks different than the st165 alltrac pad.
Doing a parts search from toyotadiy shows different part numbers
04465‑20430 Front Pad for 1988 North American TOYOTA CELICA (ST165L-BLMVZK)
vs
04465‑20280 Front Pad for 1990 JDM TOYOTA CELICA (ST185-BLMVZ)
I also found these posts that seem to show the same issues...
http://alltrac.net/phpBB2/viewtopic.php?f=8&t=29092&p=273833&hilit=gt4+brake+pads#p273833
Charly003 wrote:I confirm you that I've a 1990 Toyota Celica GT4 JDM with 2 pots... and I'm having hard time to find pad and rotors...
I looked at the ST165 Pad spect and it really doesn't look the same as mine....
http://alltrac.net/phpBB2/viewtopic.php?f=50&t=30255&p=285615&hilit=gt4+brake+pads#p285615
ianpen wrote:yeah i'have'nt looked anywhere too, r u sure it's gonna fit on our 2 pot setup caliper, because i went to partsource, autovalue , napa and even World pac . i basically i went thru almost all toyota pads from corolla to even 4 runners,lol. and 1988 alltrac from what i can remember and it's the wrong one.
Should I just order the st165 alltrac pads and see if they fit?
I was thinking to order EBC greenstuff brakes for the st165 alltrac for my car. Are these any good?
The pic below doesn't seem to match my brakes.
canadiazn
Postby klue » Tue Oct 12, 2010 4:08 am
I will ask someone I know with a JDM car to confrim. Give me a day or so when I last saw the calipers they looked identical.
Postby canadiazn » Wed Oct 13, 2010 8:10 pm
I think you're probably right. I think my mechanic is probably mistaken - I looked at my calipers today... the pads look exactly like the picture I posted... I'm not sure about the dimensions though - but I think it should be ok.
canadiazn
Postby ~CDUB~ » Wed Oct 13, 2010 10:27 pm
sorry I didnt see this thread earlier but I will 100% confirm that early JDM st185s use st165 front brakes. Rear is the same.
I went with some porterfield brake pads and probably will again.
Curtis
98 Eclipse Turbo
94 ST-205 Gt-Four
91 ST-185 Gt-Four
91 MR2 SW20 G limited
~CDUB~
Postby canadiazn » Wed Oct 13, 2010 10:37 pm
Ya - my mechanic made a mistake... the ones in the pic are the right ones.... Finding a supplier for these however, is difficult
Thanks for all your help Klue
canadiazn
Return to Canada
