Intake Piping
Intake Piping
Postby celicaracer18 » Sun Sep 12, 2004 9:29 pm
ok i am putting in a 3sgte from a MR2 into a 95 celica st i will be running on factory IC for about the first 2500 miles then i'm getting a FMIC, when i do that what size piping should i get i was under the impression that 3" is the best but a couple of people are now telling me that thats too big on stock motor, but what i keep saying is that it won't be stock, click on the link in my sig for all my engine mods that will be in.
celicaracer18
Postby Gary » Sun Sep 12, 2004 10:25 pm
Sig? 3" is probably overkill.
93 ST185
Gary
Postby alltracman78 » Sun Sep 12, 2004 11:04 pm
Yeah, there's no sig.....
Postby celicaracer18 » Sun Sep 12, 2004 11:24 pm
i put it in my sig right after i amde the post i guess it can't attatch it because it wasn't there when the post was made :shrug:
celicaracer18
Postby celicaracer18 » Mon Sep 13, 2004 5:28 pm
ok can 3" hurt anything, i want 3" so that when i do get to the point where it becomes helpful (when i upgrade the turbo) i won't have to get all new piping fitted and welded and have to rip all the old out
celicaracer18
Postby Griffin » Mon Sep 13, 2004 6:01 pm
eh - I have 2 1/4 from turbo to IC and 2.5" from IC to TB on mine. The intake pipe from my turbo to filter is a 2.75"
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby turbo4wd » Mon Sep 13, 2004 6:26 pm
Griffin wrote:eh - I have 2 1/4 from turbo to IC and 2.5" from IC to TB on mine. The intake pipe from my turbo to filter is a 2.75"
same here.. cept my intake piping is 3" (only thing i had readily avail)
I dont see how doing 3" for intercooler piping will help.. because you'll have to use reducers at the tb and intercooler end tanks unless of course youve got a 3" path for the entire system.. not to mention hood clearance issues..
Dan
Undercover Moderator
turbo4wd
Postby busdriver » Mon Sep 13, 2004 6:40 pm
According to Corky Bell 2.5 inch tube is adequate for up to about 600 bhp.
"resist the temptation to use larger diameter tubes than necessary as little drag is created in smooth tubes with gentle bends. Larger tubes will only add to the volume of the IC system, and that is not a good thing to do."
Just as a side note, with fluids the force exerted is proportional to the ratio of the areas. So if you go from a 2 inch turbo, to three inch pipe, your force is only 4/9 of what is was in the turbo. So say inside the 2" turbo outlet you were making 18psi, once you hit the 3 inch pipe it drops to 8psi. I think once it hits the 2" throttle body it will even out, but you are adding a hell of a lot of area there.
Just my 2 cents.
Jake
90 st185
needs tlc
busdriver
Postby alltracman78 » Mon Sep 13, 2004 8:36 pm
Any kind of flow system is only as good as the smallest part. I would stick with the turbo/ic/tb size hose.
Postby Conrad_Turbo » Mon Sep 13, 2004 8:59 pm
alltracman78 wrote:Any kind of flow system is only as good as the smallest part. I would stick with the turbo/ic/tb size hose.
Yep, the least amount of reducers and the opposite, the better.
Conrad Andres
Mint Design
mint-design.ca
Conrad_Turbo
Postby lhoy12 » Mon Sep 13, 2004 10:27 pm
celicaracer18 wrote:ok can 3" hurt anything, i want 3" so that when i do get to the point where it becomes helpful (when i upgrade the turbo) i won't have to get all new piping fitted and welded and have to rip all the old out
It may not "hurt" anything. But it could create excess turbo lag until you get a larger turbo that will push enough air where piping that large is useful. There is a possibility that a small turbo pushing air through 3" piping will have a lower velocity compared to a larger turbo pushing a lot more air which will give you higher velocity. Sorry if this doesn't make sense, I'm having a hard time trying to figure how to say it quickly yet understandably. It may also possibly cause more pressure drop.
lhoy12
Postby celicaracer18 » Tue Sep 14, 2004 5:02 am
ok so it looks like i'm getting 2.5" since thats the easiest to find anyways, i am going to get 3" from the filter to turbo though
but the intercooler i was going to get has 3" inlet/outlets, so wil that decrese performance or should i look for a diff intercooler (its a Hybrid ic)
also BTW what size is the the Throttle body on a 2nd gen 3sgte from a 93 MR2 ihave heard diff. things
celicaracer18
Users browsing this forum: Baidu [Spider] and 2 guests
