Aftermarket Intake Manifold? . . .
Postby gearhead313 » Tue Sep 14, 2004 7:21 pm
Does anyone know if there are side feed aftermarket intake manifolds out there? Im just got my motor out and am looking into different things i would like to get. I've seen some custom ones, but i didn't know if anyone actually produced one.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby ___Scott___ » Tue Sep 14, 2004 7:27 pm
This is side feed but that's about all I know about it:
http://www.rossmachineracing.com/mr2intake.html
Scott
Colorado Springs, CO - USA
SONY
Opera - The better browser
___Scott___
Postby allblackalltrac » Tue Sep 14, 2004 7:31 pm
*Homer voice*mmmmm..RMR intake...*drool*
SupraCelifragilisticexpialidocious
super- "above," cali- "beauty," fragilistic- "delicate," expiali- "to atone," and docious- "educable," the sum meaning roughly "Atoning for extreme and delicate beauty while still being highly educable."
allblackalltrac
Postby toayoztan » Tue Sep 14, 2004 9:53 pm
How much would something like that in power gain help? Just curious if the price is worth the power gain.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby alltracman78 » Tue Sep 14, 2004 10:11 pm
Looks nice, but I'm not too enthusiastic about the square plenum. The change from plenum to runner should be a curve, not a corner.
*The JUN one is really pretty, and looks to be more efficient. Keep in mind a manifold for a MR2 probably won't fit into your car without mod. Also, the manifold probably won't make much difference 'till you get bigger tb/cams/headwork (maybe), ect. :shrug: *
Postby Colin T » Tue Sep 14, 2004 10:14 pm
Well, it's not necessarily HP numbers I look at with the intake. It allows you to run the intercooler piping along the side, not directly next to the turbo. Also, and this is the biggest issue, it allows each cylinder to get fed more evenly than with the stock intake manifold. Notice why everybody puts their EGT probe on the 3rd exhaust manifold runner, that's the cylinder that runs the leanest, because of the way the intake manifold is dog-legged. This almost elimintates that.
Colin
Colin T
Postby mtbgael » Tue Sep 14, 2004 10:15 pm
I thought one of the big advantages to an aftermarket intake manifold is that they will solve the problem of 2 of the cylinders running leaner than the rest, not just increased efficiency...
edit: someone posted while I was...heh
Restoring an '88...
mtbgael
Postby RedCelicaTRD » Tue Sep 14, 2004 10:16 pm
Just use an 86-89 celica gts with the 3sge intake manifold. It bolts onto the ST165 and ST185 and you can get them for cheap.
Postby alltracman78 » Tue Sep 14, 2004 10:22 pm
Snafubmx234 wrote:Well, it's not necessarily HP numbers I look at with the intake. It allows you to run the intercooler piping along the side, not directly next to the turbo. Also, and this is the biggest issue, it allows each cylinder to get fed more evenly than with the stock intake manifold. Notice why everybody puts their EGT probe on the 3rd exhaust manifold runner, that's the cylinder that runs the leanest, because of the way the intake manifold is dog-legged. This almost elimintates that.
Colin
Agreed. I personally wouldn't pay $$$ for a intake manifold that would mess up flow. I am not too sure what the flow charicteristics are of that particular manifold, but I know air prefers to flow in a smooth curve instead of a sharp corner.
Postby alltracman78 » Tue Sep 14, 2004 10:23 pm
RedCelicaTRD wrote:Just use an 86-89 celica gts with the 3sge intake manifold. It bolts onto the ST165 and ST185 and you can get them for cheap.
Good tip :wink:
It will also eliminate the T-VIS on the 185.
Postby RedCelicaTRD » Tue Sep 14, 2004 10:45 pm
Nope, you'll still have TVIS. They also used it on the GTS 3sge. It says TVIS right on the manifold.
Postby alltracman78 » Tue Sep 14, 2004 10:52 pm
Oh, didn't know that. I thought they didn't have it on the earlier Celicas :shrug:
Postby billprice » Wed Sep 15, 2004 9:58 am
alltracman78 wrote:Looks nice, but I'm not too enthusiastic about the square plenum. The change from plenum to runner should be a curve, not a corner.
This is the manifold that I use. I can verify it is far superior to the stock or the JUN. Call Tom and talk to him about it before you take this advice. BTW, I don't see any "corners" in the change from plenum to runner. Beauty, I guess, is truly in the eyes of the beholder. And just because the JUN "looks" to be more efficient, does not mean that it is. Get some cfm ratings and compare and I'll bet you will be surprised. As far as "a MR2 probably won't fit into your car without mod"......LOL.......all I will say is, wrong.
'07 GS350 AWD
'09 Toro Z5030 ZTR 23hp of lawnmowing fun
billprice
Postby billprice » Wed Sep 15, 2004 10:14 am
alltracman78 wrote:Agreed. I personally wouldn't pay $$$ for a intake manifold that would mess up flow. I am not too sure what the flow charicteristics are of that particular manifold, but I know air prefers to flow in a smooth curve instead of a sharp corner.
Just where are these sharp corners to which you allude? I suppose you would think that if the plenum were round it would flow more? Not. Once you fill the plenum, moving the air FROM the plenum to the intake is where flow dynamics takes place. If you will look at the inside view of the plenum, you will see that all the runners have smooth flowing characteristics. Again, I encourage you to call Tom Ross (410-575-6100), or email him (turbotom@rossmachine.com) and ask him anything you like. Compare cfm or flow ratings btween stock and/or JUN and his manifold. It is a work of art. We got 35+ wheel horsepower more by going to this manifold. I want to stress though, that my stock exhaust manifold was changed at the same time and I do have 264 degree cams, so the extra 35+ horsepower was not from the intake manifold alone! But common sense tells you that you can't pick up 35 wheel horsepower from the exhaust alone either! I think a fair assessment would be 15-20 whp from the manifold, depending on your mods, which would be 18-24 at the crank. Not too bad for your outlay of hard earned money, and the bonus effect of not having the problem of running lean in any cylinder.
'07 GS350 AWD
billprice
Postby gearhead313 » Wed Sep 15, 2004 12:35 pm
I think any manifold will make more power than the stock st165 manifold whose runners are about 47miles long. My main consern was intercooler piping. Making it that much easier to get things plumbed makes me happy.
What people never realize when talking about intake manifolds is that there isn't a constant rush of charge running through it. I mean, there is, but its not constant. When intake valves close, and you have a few hundred cfm of air coming at it, where does it have to go but bouncing off the intake vavles, surging back up into the manifold. The design of the tank is very important to controlling these surge's that happen at a very high and erratic movement.
One of the only companys that has addressed this and has made VERY high hp numbers is the JDM manifold for nissan maxima's. Theirs is a very complicated dual runner design that is engineered amazingly and supposedly has put down over 50hp or something like it on USDM motors. Its been a while since i've been over to the nissan world, so im probably not real clear on it. It was definitly something very sought after though.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
gearhead313
