Low-end performance?
Postby 92 All-Trac » Mon Sep 20, 2004 1:47 am
Like stated above, give it a good tune up. But I'm also willing to bet that exhaust is causing the majority of the problem you're describing. I got rid of my cats and it made a world of difference on my car. When from a 16.3 in the 1/4 bone stock, to 15.2 with strait pipe exhaust and a new air filter.
Josh
1992 ST185
92 All-Trac
Postby alltracman78 » Fri Sep 24, 2004 2:57 am
damn
Postby gpmarzan » Tue Sep 28, 2004 3:41 pm
my st165 is actually having the same issue youre having. the car will start to spool around 1500 or so, and im pretty sure it reaches full boost around 2500-3000. the car will pull but i get that hard pull when it reaches around 3200 or so, and thats from gunning it from a stop. i remember when it didnt pull till i was around the 3900k rpm range so i changed my cap/rotor and it pulled a lot sooner and better. from a stop its like a; pull..pull..pull..then a really hard pull when i hit 3200k. i dont know if this is normal or not.
gpmarzan
Postby CodingParadox » Tue Sep 28, 2004 7:20 pm
Did you check your ignition timing? This is exactly what was up with my car, and then I checked my timing and it was 10 freaking degrees off. :)
CodingParadox
