?'s about FMIC piping size and clocking turbo
Postby presure2 » Fri Sep 17, 2004 2:45 pm
hey all, im planning a st-185 to st-204 swap, and trying to decide on what size piping to use for my FMIC. the core is gonna be 23x6x3, i am planning to run about 12lbs or so.
now im just trying to decide between 2.5" or 2" piping for the intercooler, and weather or not i should try and clock the turbo and go that way with the piping, although looking in the engine bay now, dont look like theres alot of room in there for piping w/the turbo clocked.. :shrug:
any thoughts, comments or suggestions are MUCH appreiciated and welcomed!
thanks
manny :smokes:
www.6gc.net for all things 94-99 celica related
presure2
Postby lhoy12 » Fri Sep 17, 2004 5:58 pm
2.5" IC piping is what most people run, you will still have good air velocity as well as getting more air moved from the turbo to ic to intake mani.
lhoy12
Postby RedCelicaTRD » Fri Sep 17, 2004 9:56 pm
If you arnt going to upgrade turbos just use 2". If you clock you need to fab up some custom brakets to hold the wastegate actuator.
Postby BoostJunkee » Sat Sep 18, 2004 3:01 am
I would say 2.5". Even if you arent going to upgrade the turbo, you might decide to one day down the road.
Stupid Honda - 13.6@100mph
BoostJunkee
Postby RedCelicaTRD » Sat Sep 18, 2004 6:19 am
anything under 600 crank hp wont need any bigger than 2-1/4". Bigger isnt better all the time.
Postby presure2 » Sat Sep 18, 2004 2:50 pm
_________________
yea, i was thinking that, so i guess that means 2"..
anyone have any detailed pics or descriptions on how exactly you clock a ct26? any help is much appreiciated!! :smokes:
manny
presure2
Postby 92 All-Trac » Mon Sep 20, 2004 1:38 am
You need a tool to take the clamps off. Not sure where to get one if those.
Josh
1992 ST185
92 All-Trac
