Bogging out
Bogging out
Postby BoostJunkee » Sat Sep 18, 2004 2:59 am
Setup: Bone Stock ST165 with a gutted cat.
Problem: Whenever get on the throttle, turbo spools, but performance isnt up to par. It sort of bogs out, then will suddenly come to life and take off. Just bogging out down low like that when the car first takes off.
Any ideas. Oh and the car has run fine except for this issue for about the last 40K miles.
Stupid Honda - 13.6@100mph
BoostJunkee
Postby Stubble » Sat Sep 18, 2004 4:13 am
Plugs, wires, cap, rotor, vacuum leak...then look in more depth like AFM.
Any codes?
Somebody else help me with this brainstorm...
Brady Ryall
1990 ST185 Red - parts
1990 ST185 Black
1999 Miata
2008 A3 Quattro S-line
Stubble
Postby Gary » Sat Sep 18, 2004 4:18 am
Did you dump the clutch when you launch?
93 ST185
Gary
Postby BoostJunkee » Sat Sep 18, 2004 4:18 am
Stubble wrote:Plugs, wires, cap, rotor, vacuum leak...then look in more depth like AFM.
Any codes?
no codes.
pretty sure all the ignition components are fairly new, always good about regular maintenance.
AFM?
BoostJunkee
Postby BoostJunkee » Sat Sep 18, 2004 4:48 am
Gary wrote:Did you dump the clutch when you launch?
no, this is a friends car, and he doesn't tend to beat on the car like that at all. He said its happening when he is on the freeway and tries to accelerate quickly, so I am assuming it happens when he downshifts and tries to get on it.
BoostJunkee
