Nitrous Wet Kit
Nitrous Wet Kit
Postby CelicaGT4 » Sun Sep 19, 2004 4:57 am
I have recently decided to buy a nitrous system for my 3sgte. I was curious to see how many of you have it, and also your ideas on the subject. I think I have made up my mind on a wet throttle response system...but I am open to ideas. Can my motor handle nitrous and would it be worth it? My mods go as follows 800cc injectors, nology ignition system, Garret T3 turbo, FMIC, stage 4 clutch, fidanza flywheel, intake and fully built exhaust, what other mods are needed for this upgrade? Will my stock internals hold up? I am trying to break 11sec. 1/4's here and am getting close, I just think I need the extra oomf.
Www.gemstatepestsolutions.com
CelicaGT4
Postby Zeus » Sun Sep 19, 2004 5:05 pm
you have all that on a t3?
i personally would swap that out for something bigger before going for nitrous...
but thats me
what are you using for enigne management? tunning would be crucial here... that is if you want to do it safely.. are you still running the stock fuel pump?
Blake Brown
Zeus
Postby CelicaGT4 » Sun Sep 19, 2004 6:25 pm
stock fuel pump, yes I do. I have plans on upgrading once I hit higher boost, but until then I will stay with stock. If I do get the nitrous kit then I will definately upgrade turbos, I'd probly go with a 20g dsm.
CelicaGT4
Postby Zeus » Mon Sep 20, 2004 3:12 am
what are you using for engine management?
Blake Brown
Zeus
Postby CelicaGT4 » Mon Sep 20, 2004 5:28 am
I am still shopping around for an ems, I don't want to go stand alone because I spent all that damn time lengthening my harness and making my ecu work. I should know what I am doing with a week or two.
CelicaGT4
Postby specops19 » Mon Sep 20, 2004 3:09 pm
why dont u use dry nos
specops19
Postby Zeus » Mon Sep 20, 2004 5:46 pm
HOw exactly are you going to run 800cc injectors on the stock ecu?
you cant even run 550's properly...
Blake Brown
Zeus
Postby AWDios » Mon Sep 20, 2004 7:15 pm
specops19 wrote:why dont u use dry nos
Doesn't work with Turbo vehicles.
www.pstoc.org
Formerly known as GT-Four195
AWDios
Postby RedCelicaTRD » Mon Sep 20, 2004 9:20 pm
Just get an AEM, plug and play. Also dry nitrous will work with a turbo car but its not recommended since your injectors are probably maxed out and cat put in enough fuel when you add the nitrous.
Postby AWDios » Mon Sep 20, 2004 10:17 pm
I thought it was also a bad idea do to the typically high intake temps.
www.pstoc.org
AWDios
Postby RedCelicaTRD » Mon Sep 20, 2004 11:22 pm
Nitrous injection of any kinda will lower your intake temps :)
Postby AWDios » Tue Sep 21, 2004 2:14 pm
well now I know.
www.pstoc.org
AWDios
Postby Zeus » Tue Sep 21, 2004 7:39 pm
and knowing is half the battle!
Blake Brown
Zeus
Postby etantshi » Thu Sep 23, 2004 11:31 pm
G.I. JOE!!!
André B.
1991 ST185 (down but not out)
1996 RZN140 (the daily)
etantshi
