bov flange
bov flange
Postby shoteh » Mon Sep 20, 2004 12:47 am
where do you guys get your bov flange welded on? and how much does the labor usually cost...Im planning to get the ssqv , how much would the bov, kit, and labor cost be going for these day?...thanks...how long would they take? because its my daily driver
shoteh
Postby maroon_185 » Mon Sep 20, 2004 12:58 am
I would suggest getting the samco T-hose from 935, would be easier and cleaner looking IMO.
Chris Fowler
1990 maroon 185 (rc swapped)
1991 red mr2 (3s swap coming soon) Dads
maroon_185
Postby shoteh » Mon Sep 20, 2004 1:07 am
would that be a bolt on..welding? cutting involved? theres a backoder on 935 right now..should I still purchase anyway? anywhere else it is found?
shoteh
Postby Gary » Mon Sep 20, 2004 1:11 am
Samco T hose is bolt on, no welding, it's silicone.
93 ST185
Gary
Postby maroon_185 » Mon Sep 20, 2004 1:23 am
yeah it attachs really easily, I would still suggest the t-hose.
Chris Fowler
maroon_185
Postby Griffin » Mon Sep 20, 2004 2:23 am
I put mine on the intercooler tank (discharge side):
Anyways I had it welded on to the inlet line when I had the stock TMIC but that was a mistake - it didn't totally clear and would rub on the hood - its very tricky where you have to place it - the Samco T hose is a way better option now that they make it.
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby omgitsroy326 » Mon Sep 20, 2004 2:54 am
dear gary.. i c after the bov u have a lil converter.... where do i get that ... also are all bov have the same inlet diameter???
omgitsroy326
Postby Gary » Mon Sep 20, 2004 11:15 am
Little converter? If you mean the recirculation kit, I think you can order it from 935motorsports.
93 ST185
Gary
Postby shoteh » Mon Sep 20, 2004 5:19 pm
gary I see that your t hose is almost vertical coming down from the Ic to the turbo. mine is a top mount a2a ic not a water and the original pipe is curved instead of straight like yours. how does that work out. wouldnt the t hose hafta be diaganol cuz both the inlet are not vertical?
shoteh
Postby Gary » Mon Sep 20, 2004 5:37 pm
OK I got it now. You are talking about T-hose on ST185. The T-hose replaces the stock hose between compressor outlet and intercooler.
btw, the pictures is not my car.
93 ST185
Gary
Postby Zeus » Mon Sep 20, 2004 5:41 pm
I wish i had known about the t hose... i would have used that instead for sure
Blake Brown
Zeus
Postby shoteh » Thu Sep 23, 2004 2:41 am
sorry j/w again. with the t hose would you need to buy the kit( the flange) or can you go with the "universal" ones without any thing extra. kind of dumb ? but jus to make sure so I dont spend anymore $ if dont have to. with the t hose all you would need is the bov itself right? :shrug: and does the ssqv fit right in the t hose?
shoteh
Postby maroon_185 » Thu Sep 23, 2004 2:58 am
not sure, ask robert, sure he knows
Chris Fowler
maroon_185
Postby alltracman78 » Thu Sep 23, 2004 3:45 am
Here's one of my BOV.
It's attached to a welded on tube though.
Postby omgitsroy326 » Thu Sep 23, 2004 9:04 am
what is the small red hose connected to the bov
omgitsroy326
