Street Brawler 46 Trim Final - 392whp@24psi, w/Exhaust!
Postby jprine01 » Fri Mar 10, 2006 9:45 pm
I have the Aussie Catback, yeah the corkscrew thing is like the resinator. Its not really 1.5inch because its not a 3" pipe there, it gets wider to like 4", so half of that is 2", but the corkscrew is only cutting the flow in half not the diamter of the pipe. Since 4" can flow almost twice as much as 3" I would say it does flow closer to 3". Anyway it is a restriction, but I think it is also the reason the aussie sounds so nice.
jprine01
Postby ST185pinjo » Fri Mar 10, 2006 10:43 pm
Nice numbersm8, nice story on your site.
keep up the good work. :notworthy:
ST185pinjo
Postby TraviST185 » Fri Mar 10, 2006 10:53 pm
TVIS?
Travis Hanson
TraviST185
Postby CodingParadox » Sat Mar 11, 2006 2:06 am
TVIS still very much intact. Taking out TVIS is stupid.
CodingParadox
Postby goldfish » Sat Mar 11, 2006 2:15 am
Nice...very nice. Have any of you seen any dyno plots comparing the SB46 with the ATS TD06 on a car with almost the same mods? I've got everything but the turbo and EMS (including full head work with OS valves and stock cams) and I'm debating between the SB46 and the TD06 (most likely with the ATS Rom tune.) I dont really want to spend much more than 4 more grand to finish the engine.
What made you decide between the SB and the ATS TD06?
I'm just looking to finish out the performance on the car with something fun on the street and even more fun on track. I think i can get pretty close to 300whp on the ATS kit - which would be enough for me. Do you have any thoughts on that considering your experience with the SB?
David G.
'91 ST185
goldfish
Postby CodingParadox » Sat Mar 11, 2006 8:39 am
goldfish wrote:Nice...very nice. Have any of you seen any dyno plots comparing the SB46 with the ATS TD06 on a car with almost the same mods? I've got everything but the turbo and EMS (including full head work with OS valves and stock cams) and I'm debating between the SB46 and the TD06 (most likely with the ATS Rom tune.) I dont really want to spend much more than 4 more grand to finish the engine.
If you want the easy cheap solution go with the TD06 and ROM tune - the SB46 will require an EMS to get the most out of it.
The TD06 is a worse turbo - less max power, but spools the same or slower than the SB46... The kit also isn't nearly as well-made. Also, Kris is a local guy for me so I'd had lots of contact with him before, and during this whole process, all of which has been great.
As long as by "track" you mean "road courses" and not "drag strip" then yeah, the spool is great. For a drag strip, screw it, just get a giant turbo and cams. The reason I got the SB46 is to get the biggest quickest spooling turbo I could.
CodingParadox
Postby goldfish » Sat Mar 11, 2006 3:41 pm
Cool...ya - by track i meant road courses. If i want a drag car I'll buy a Supra. Unfortunately for me, the only reputable tuners are over 200 miles away. I develop software, but I dont know enough about tuning to want to give it a try without learning from someone else for a long time. Over the last year I've been working too much to have time to enjoy the car during the week....especially when it isn't running because I'm doing someting to it. I just want to be done with it so i can take it out for a drive after a long day of work...
David G.
'91 ST185
goldfish
Postby Simba » Sat Mar 11, 2006 8:43 pm
goldfish wrote:If i want a drag car I'll buy a Supra.
If you want a drag car, buy a Mustang. Supras suck at it. :D
'course, that doesn't stop people from flinging the things into the 8's, but like the AT, Supras were designed to turn.
Lots of fast, loud things.
Simba
Postby grip addict » Sun Mar 12, 2006 10:18 pm
so when do you see full spool by david? i'm really curious to see how it compares to the stock turbo as far as that is concerned. if you have some time, a video of the boost guage would be awsome proof of how quick you see your power.
i need to warn everyone-
grip addict
Postby CodingParadox » Sun Mar 12, 2006 10:21 pm
I think it gets to 24psi at like 4700. 200wtq by 3700.
I don't have a video camera, so that'd make it kinda hard to do any vids. I'll let the dyno plot speak for itself whenever Kris posts it.
CodingParadox
Postby furpo » Sun Mar 12, 2006 10:52 pm
david, well done on the result.
i was just wondering if you where logging the delta - p on the dyno (difference between intake and exhaust manifold pressures)? the reason i ask is that you state you have reached the limit of the cylinder head flow and that also your turbo turns on nice and yearly. this would suggest to me that the turbine side of the turbo maybe starting to become a restriction which is usually the case when you start making less power the more you turn the boost up. when a turbine becomes a restriction exhaust manifold pressures go through the roof and the delta - p becomes less (i.e. there is less of a 'head' accross the cylinder head).
anyway just food for thought and it would be interesting to see what affect going to a larger turbine housing has.
roger
furpo
Postby CodingParadox » Sun Mar 12, 2006 10:55 pm
That's possible. We weren't logging that at all though, unfortunately. =/
CodingParadox
Postby hinkle » Mon Mar 13, 2006 3:04 am
that is the worst advice ive ever heard :P
i hope ur talking about those huge turbos sucking
06 LTR 450
hinkle
Postby CodingParadox » Mon Mar 13, 2006 5:03 am
Torque dropped off heinously compared to open DP. New exhaust should pop me well over 400whp...
CodingParadox
Postby Hic » Mon Mar 13, 2006 7:41 am
Hi Coding,
very nice result, completely enough in my opinion. I was wandering what was your EGT (before turbo) on WOT? Did you measure it? Also, iI think Furpo is on the right track when saying that exhaust housing on the turbo is being restrictive...you will gain someting going to full 3" (without resonator", but also 3.5" exhaust would do you some good :)
Hic
