Street Brawler 46 Trim Final - 392whp@24psi, w/Exhaust!
Postby theUNYTEDone » Thu Jun 01, 2006 4:21 am
hey chris, any idea what's a safe level of boost on pump gas to get 300 daily HP?
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby CodingParadox » Thu Jun 01, 2006 5:09 am
300whp daily can be gotten with around 18-19psi on pump with conservative timing on stock cams.
My understanding is that the 46 trim, even with cams, won't see 450 to the wheels. You should ask kris for more info. I could be completely off basis. Kris will know more about the turbo's capability than James.
CodingParadox
Postby Denver_whiteST185 » Thu Jun 01, 2006 5:14 am
would a 50-trim SB kit be able to get 450 to the wheels on race gas? I'm planning on stroking my engine to 2.1 or 2.2, so that would make up for spooling difference.
^Ted^
Denver_whiteST185
Postby CodingParadox » Thu Jun 01, 2006 5:22 am
I just asked Kris, and he agreed that the 46 trim can't hit 450 to the wheels, it just doesn't have quite enough flow. Cams won't help improve maximum flow of a turbo, they'll just help improve VE if your head is the restriction, not the turbo.
Kris thinks the 50 trim could do it pretty easily, however. So, you can go that route.
CodingParadox
Postby Denver_whiteST185 » Thu Jun 01, 2006 5:31 am
sounds good. I just got a new job and im finally going to have the money to start building up my car. Im inbetween a garret GT30 kit ive found and the Street brawler kit. However, if kris is planning on making a streetbrawler upgrade to a Garret GT series like he was talking about, im definatly going for that. My car should be ready for 25psi by october, so thats when im looking to get that kit. the reason i was wondering is because my goal is 450-500 on race gas and 350 on pump gas while retaining a decent spool (remember, im at 6000 ft., so my spool is 500 rpm or so later)
^Ted^
Denver_whiteST185
Postby toayoztan » Thu Jun 01, 2006 7:14 am
CodingParadox wrote:I just asked Kris, and he agreed that the 46 trim can't hit 450 to the wheels, it just doesn't have quite enough flow. Cams won't help improve maximum flow of a turbo, they'll just help improve VE if your head is the restriction, not the turbo.
Hey thanks for talking to Kris for me David. I'll definitely get the 50 trim then. And i'm liking the idea of getting it anyways because if i want more power than 450, at least i know i won't be pushing it hard hard like i would be with the 46trim, if that makes sense.
Denver_whiteST185 wrote:sounds good. I just got a new job and im finally going to have the money to start building up my car. Im inbetween a garret GT30 kit ive found and the Street brawler kit. However, if kris is planning on making a streetbrawler upgrade to a Garret GT series like he was talking about, im definatly going for that. My car should be ready for 25psi by october, so thats when im looking to get that kit. the reason i was wondering is because my goal is 450-500 on race gas and 350 on pump gas while retaining a decent spool (remember, im at 6000 ft., so my spool is 500 rpm or so later)
Looks like we're on similar paths. Though I won't be going to a stroker kit, our HP goals are similar. Talk to me when you're ready to buy your parts. I'm curious as to which brand/type/etc that you're going with, to help get some ideas and compare.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby CodingParadox » Thu Jun 01, 2006 7:49 am
np. I was on the phone with him to talk about something else and just asked while I was at it. :)
Keep in mind that, as Denver mentioned, Kris will happily bundle a GT series turbo of your choice with the kit instead, for an appropriately increased price (GT turbos are more expensive than the turbonetics equivalents.) So, if you would rather get a GT30 more suited for your application, you can go that route too.
CodingParadox
Postby Denver_whiteST185 » Thu Jun 01, 2006 1:41 pm
toayoztan wrote:Looks like we're on similar paths. Though I won't be going to a stroker kit, our HP goals are similar. Talk to me when you're ready to buy your parts. I'm curious as to which brand/type/etc that you're going with, to help get some ideas and compare.
Bryan
here, ill send you a sheet of my planned mods. I made it mostly to keep ideas on paper.
^Ted^
Denver_whiteST185
Postby theUNYTEDone » Thu Jun 01, 2006 10:28 pm
hmm....any news on the GT series for the SB kit? :evil:
Nigel in Hawaii
From Hell and Back
theUNYTEDone
Postby CodingParadox » Thu Jun 01, 2006 10:30 pm
I'm pretty sure you can currently do a GT order and he has the kit modified appropriately for it, but I could be wrong. Give them a call or email and ask.
www.koracing.net
CodingParadox
Postby KORacing » Sun Jun 04, 2006 5:58 pm
450whp with the 46 seems outside the realm of reality to me. Garrett rates the turbo at about 380hp (crank) and we've obviously proven it can do much more than that as my stock VE car makes 375whp with that turbo, and David's a bit more. The 50 trim will do it without question as we've done it several times with the MR2s, whereas the 46 is just about done *with a reasonable boost level* at around 400 or just over. We've had 2 different MR2's make around 410whp with the 46, one at 22psi with a fully built engine Engine Logics engine on race gas, the other at 25psi with 264 cams, methanol injection, and pump gas (on a stock ecu). The second car has pushed the turbo to over 30psi with some boost spikes, but the map starts to lose efficiency above 25psi, and I wouldn't recommend following in that car's footsteps (the owner is a bit of a lunatic).
We can do a GTseries kit now (30R or 35R), but we have not advertised it for sale yet as it is not fully tested and I'm not really happy with the water line setup as of yet.
Kris/Lilly Osheim
KO Racing, Inc.
www.koracing.net
MR2 Turbo "Loki" -- 11.1 @ 128mph
Hydra Nemesis EMS PnP Exclusive distributor for 3SGTE Celica Alltrac/GT4
Certified Hydra Tuner -- I will travel to tune.
KORacing
Postby Griffin » Wed Jun 07, 2006 5:30 am
I'll let you know how the turbo does on what should by all rights be a VE monster once I have mine put together. I'll be happy with 400 to all 4, extatic with anything above that.
Dave Staba
SOLD - 1990 Black ST185
Sealy, TX
Griffin
Postby CodingParadox » Wed Jun 07, 2006 7:09 am
What'd you do to make it such a "VE monster"?
CodingParadox
Postby Griffin » Thu Jun 08, 2006 4:15 am
CodingParadox wrote:What'd you do to make it such a "VE monster"?
So far I have Chris K built Head with 1mm oversize valves full port correction and P&P, HKS 264 cams & valve springs, 1ZZ shims, upgraded oil pump, Chris K and RMR intakes w/ 70mm mustang TB (will use whichever is better - I bought both) and then of course my FMIC
I *will* also have a port matched and ceramic coated exhaust manifold, turbo adapter and turbine (still working on that stuff - been too busy to do it) I'm also swapping to a DIS setup with 1ZZ coils. (have the coils and connectors but need to install them)
This setup should also let me run about 8750 / 9000 RPM no prob.
Thats basically every breather mod you can do for VE on the motor.
Dave Staba
Sealy, TX
Griffin
Re: Street Brawler 46 Trim Final - 392whp@24psi, w/Exhaust!
Postby 1BADGT4 » Wed Jul 02, 2014 9:06 am
Has there been anyone else with huge numbers with the SB kit?
UT2 (SCW) Chan - Oakland, CA
04 Duc Monster DS
400BHP @ 20#, low 12s
1BADGT4
