Zeroing the Boost Gauge
Postby SuperSprynt » Thu Sep 23, 2004 6:36 pm
When I got my gauge it was perfectly on 0lbs, now its almost a full -1, does anybody know IF a gauge can be recalibrated or is this common and crappy all in one?
Autometer btw.
SuperSprynt
Postby illGT4 » Thu Sep 23, 2004 8:05 pm
I don't think you can zero it.. :(
1 autometer gauge I had never moved from 0
the other 1 was slightly under 0 :(
Imagewww.illtuned.com
- Vehicle Dynamics Specialist
illGT4
Postby alltracman78 » Fri Sep 24, 2004 2:59 am
Havn't had mine do that yet... :?
Call autometer and ask them, that's your best bet.
Postby SuperSprynt » Fri Sep 24, 2004 2:55 pm
Correction, since I posted its now on -1lbs.
SuperSprynt
Postby CMS-GT4 » Fri Sep 24, 2004 3:03 pm
Does this guage show negative? Stock engine should be showing around -15hg when at idle. I have never heard of a boost guage that sits on 0 unless it does not show negative.
Postby toayoztan » Fri Sep 24, 2004 4:22 pm
And just to clarify, negative isn't in "lbs", it's in "in Hg" if the gauge shows vac.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby alltracman78 » Sat Sep 25, 2004 1:32 am
CMS-GT4 wrote:I have never heard of a boost guage that sits on 0 unless it does not show negative.
I think he means when the engine isn't running.
And engine should be at 18-20 in/hg.
15 in/hg is a little weak.... :|
Postby SuperSprynt » Sat Sep 25, 2004 1:53 am
Yeah im talking about when the car is off. When im idling cold its 18, warm 20.
SuperSprynt
Postby toayoztan » Sat Sep 25, 2004 2:51 am
mine sits at -1 in Hg when the car is off too...i don't think it's really important much, as long as it says 18-20 in Hg when idling. And yeah, 15 in Hg would be pretty weak...suggests pretty good vac leak.
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
2015 Grom
1977 GL1000
toayoztan
Postby Gary » Sat Sep 25, 2004 3:41 am
Could it be that there is small vacuum left behind the TB when engine is off? :shrug:
93 ST185
Gary
Postby furpo » Sat Sep 25, 2004 3:49 am
wha sort of boost have you been running. i mate of mine has a 4g61 mitsi running up to 26 psi boost and before he got the right gadge it would move around quite a bit.
roger
furpo
Postby alltracman78 » Sat Sep 25, 2004 8:55 am
Gary wrote:Could it be that there is small vacuum left behind the TB when engine is off? :shrug:
Doesn't matter. The air pressure inside the engine (once it's off) will be the same as outside. Abient pressure should be 0psi.
Postby gearhead313 » Sat Sep 25, 2004 2:18 pm
I had the same problem a while back...
What you do is take the bulb out and inside you can see a curlyQ type spring thing. Jam a small screwdriver in there and lightly start pusing inward or then outward on the spring and watch the needle move. Once u tweek around in there, you'll be able to get it exactly where u want it.
ST165 counter:
#2597 - fail
#3193 - fail
#xxxx - sold
#4598 - sold to Canada eh
gearhead313
Postby RedCelicaTRD » Sat Sep 25, 2004 5:24 pm
Ambient pressure is not zero. Pressure varries from day to day within a certian range. You elevation will change it the most. however at my elevation i would have ~4 inches of Hg vacuum which is way more then my gauge shows so it is possible the gauge is a piece of shit.
Postby CMS-GT4 » Sat Sep 25, 2004 8:01 pm
I do live in the hills of tn, mahaps my evelvation is related.
