Going with Aussie full system soon and need help?
Postby vondoom » Thu Sep 23, 2004 8:14 pm
hey guys- now ive installed any number of exhausts from cat back to full in all manner of hondas, but having owned this picky little beast we call the alltrac for a coupla years now, ive learned not to take any chances, and seing as im gearing up to buy the ausie exhaust system hopefully in the next month or so, i wanted to check with you guys to see what im gonna need as far as tools and what to look out for ie: general issues and problems. also, how much downtime were looking at here. thanks allot for all your help.
AJ
Frosty Jack
1990 ST185 (still love needed)
1973 RA21 Celica ST
vondoom
Postby illGT4 » Thu Sep 23, 2004 8:25 pm
others def. know more.. but here is what I recall.
Be sure to tighten everything slowly... meaning do no tighten one part of the exhaust completly, then move on to the next.
you want to slowly tighten each section of the exhaust (dp to front, front to mid, etc..) to be sure that you don't get rubbing on the cross member.
Other than that, it's completly bolt on, and shouldn't take you too long to accomplish, especially if you have a lift or another person handy..
Good Luck,
Imagewww.illtuned.com
- Vehicle Dynamics Specialist
illGT4
Postby alltracman78 » Fri Sep 24, 2004 3:03 am
Prolly going to need to knock a [small] dent in the pipe where it goes over the fr cross member.
Also, make sure it's tight, as in the whole exhaust. If it's loose, it will have more play, and rattle.
Postby vondoom » Fri Sep 24, 2004 4:38 pm
tighten slowly, got it, much like one does with rims, screw all the lugs in and then tighten everything down
1973 RA21 Celica ST
vondoom
Postby vondoom » Fri Sep 24, 2004 4:39 pm
so there are clearance issues with the exhaust going over the front crossmember?
1973 RA21 Celica ST
vondoom
Postby alltracman78 » Sat Sep 25, 2004 1:35 am
Yes, it will rattle if you don't knock a dent.
Postby vondoom » Sat Sep 25, 2004 4:06 am
ok, once again working with limited experience here, how does one 'knock a dent' are we just talking about taking a hammer to it to bend it so it clears the crossmember?
1973 RA21 Celica ST
vondoom
Postby Gary » Sat Sep 25, 2004 4:13 am
evolv [iceman] wrote:ok, once again working with limited experience here, how does one 'knock a dent' are we just talking about taking a hammer to it to bend it so it clears the crossmember?
You got it right!
Or you could put spacers/longer bolt there.
93 ST185
Gary
Postby Midnightracer22 » Tue Oct 05, 2004 4:53 am
pics? of spacers/longer bolts... im iffy on knocking dents...
Rebuilding the YJ from the (sand in the) frame up
Midnightracer22
Postby RIalltrac » Tue Oct 05, 2004 12:49 pm
Ya forget that dent, I personally think this system is too expensive to dent. you could take a sledge to your crossmember in that area, off the car of course. Or you can buy bolts that are longer than the ones currently holding crossmember on, then put a washer or two above the crossmember to drop it a couple mm's, others have done this without problems and I will once I stop being lazy :P
Chris - 90 ST185
RIalltrac
Images: 2
Postby alltracman78 » Tue Oct 05, 2004 3:10 pm
Dent doesn't have to be that bad....
Postby toayoztan » Tue Oct 05, 2004 4:48 pm
illGT4 wrote:you want to slowly tighten each section of the exhaust (dp to front, front to mid, etc..) to be sure that you don't get rubbing on the cross member.
I don't mean to question you, but is it just me, or have i seen it posted some time in the past that the proper way to tighten up the aussie exhaust is from the rear to the front? If i'm wrong, then nevermind what i'm talking about :D !
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby silverarrow » Tue Oct 05, 2004 5:00 pm
When I had the aussie mp and catback I didn't need to knock a dent at all. Fits perfectly like stock.
89 240sx
07 Versa SL
silverarrow
Postby alltracman78 » Tue Oct 05, 2004 5:17 pm
Don't think it matters which way you tighten it.... :|
The midpipe fits fine, as long as it doesn't move, once it starts to vibrate, and flex with the engine, it will rattle agains the crossmember.
Unless maybe you have just the right tolerances.
Postby BraveUlysses » Tue Oct 05, 2004 6:21 pm
silverarrow wrote:When I had the aussie mp and catback I didn't need to knock a dent at all. Fits perfectly like stock.
Thats funny because the catback I bought from you rattles like crazy. I need to go bang it around a bunch I think.
BraveUlysses
