Bypass valve
Bypass valve
Postby Killerguppy » Mon Aug 09, 2004 11:42 pm
I just installed a bypass valve (Bosch) into my 88' Alltrac (has a 93 Jap import). I am wondering if anyone has a decent photo of where to install the vacuum line from the bypass valve. Or can someone point me in the right direction.
Thanks
Killerguppy
Postby RedCelicaTRD » Mon Aug 09, 2004 11:47 pm
Tap into any line AFTER the throttle body. The one going to the fuel pressure regulator is a good choice.
Wayne
1990 All Trac
2017 SRT Challenger Hellcat
Grumpy Moderator
RedCelicaTRD
Postby alltracman78 » Tue Aug 10, 2004 12:21 am
There's a cap on a v port on the back of the manifold, near the map sensor. It works nice.
Postby Gary » Tue Aug 10, 2004 1:47 am
Here is the one alltracman78 is talking about.
93 ST185
Gary
Postby Killerguppy » Tue Aug 10, 2004 12:37 pm
These ports seem to be of larger diameter tubing than what my bypass valve uses, should I just use an adapter to couple them together?
Thanks
Killerguppy
Postby Gary » Tue Aug 10, 2004 2:57 pm
Killerguppy wrote:These ports seem to be of larger diameter tubing than what my bypass valve uses, should I just use an adapter to couple them together?
Thanks
Sure you can. :wink:
93 ST185
Gary
Postby RIalltrac » Tue Aug 10, 2004 10:33 pm
I'm bout to install my new topmount/bov & a boost gauge, can I use that one port for both? or is that overkill for that particular port?
Chris - 90 ST185
RIalltrac
Images: 2
Postby mototebok » Tue Aug 10, 2004 10:58 pm
Yes you can, both are sealed air passages. Go for it.
Just get a reducing Y for it then ;)
-Adam
'88 Alltrac .... Got a shiny new turbo
'94 RX7 .... Other money black hole
'00 ZX6R .... Lime Green Speed Machine
mototebok
Postby ChrisD » Thu Aug 12, 2004 1:46 pm
edit
1988 ST165
1994 ST205 WRC
ChrisD
Postby zblu81 » Mon Aug 16, 2004 1:49 am
Is the bosch bpv any better than an MR2 bpv? How much does the bosch cost and where did you get it?
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
3" Exhaust, RC intercooler, ATS TD06-20g, stage2 clutch
zblu81
Postby alltrac.net » Mon Aug 16, 2004 1:59 am
The bosch is not as good as the MR2 in design. However, it operates well and smoothly and installation is quite easier.
ST165, then ST165, then ST185, then ST165.
Yes I've been there.
alltrac.net
Site Admin
Postby zblu81 » Tue Aug 17, 2004 1:25 am
what makes the bosch valve easier to install? Doesn't the MR2 bpv require VTV as well?
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
zblu81
Postby toayoztan » Tue Aug 17, 2004 2:23 am
zblu81 wrote:what makes the bosch valve easier to install? Doesn't the MR2 bpv require VTV as well?
I know the mr2 bpv HAS the VTV, b/c that's what i'm missing. However, i was told that it wasn't needed...I'm wondering if this is true? because otherwise, that part is 49.xx bucks from Toyota.
Thanks
Bryan
2017 Pilot Elite
2014 Juke NISMO RS
1994 Supra TT 6spd
1993 Alltrac - http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=37466
1977 Celica GT Liftback
2015 Grom
1977 GL1000
toayoztan
Postby zblu81 » Tue Aug 17, 2004 3:33 am
if an MR2 owner switches to an aftermarket bov wouldn't that eliminate their need for the vtv?
[b][/b]Greg
Lansing, MI
'92 turbo All-Trac
zblu81
Postby alltrac.net » Tue Aug 17, 2004 5:08 pm
Another engine that uses the same valve like MR2, does not have a VTV. Just T the line going to the top to the bottom. Should work fine.
The bosch valve is small, fits right into a SAMCO T hose, and points towards the intake.
The MR2 valve is a large beast and takes lots of work to install into a T hose. The pressure side of the MR2 valve is a FLANGE, which looks strange but still installs to the tube.
alltrac.net
Site Admin
Users browsing this forum: No registered users and 7 guests
